infrastructure:services:unifisnapshotgetter [2019/08/16 11:14]
infrastructure:services:unifisnapshotgetter [2021/10/20 23:32] (current)
jabelone
Line 2: Line 2:
 This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/​webcams/​. These snapshots are used in the [[infrastructure:​services:​memberportal|member portal]] and the [[infrastructure:​HomeAssistant|home assistant]] instance. This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/​webcams/​. These snapshots are used in the [[infrastructure:​services:​memberportal|member portal]] and the [[infrastructure:​HomeAssistant|home assistant]] instance.
-More information and documentation is available in the github repo [[https://​github.com/​HSBNE/​UniFiVideoSnapshotGetter|here]]. +===Useful Info===
 **Author(s):​** Jaimyn (@jabelone)\\ ​ **Author(s):​** Jaimyn (@jabelone)\\ ​
-**Current Maintainer(s):​** ​Jaimyn ​(@jabelone)\\  +**Current Maintainer(s):​** ​No one :(\\
-**Running On:** [[infrastructure:​servers:​porthack01|Porthack01]]+**Running On:** [[infrastructure:​servers:​porthack01|Porthack01]]\\
 +**GitHub:** [[https://​github.com/​HSBNE/​UniFiVideoSnapshotGetter|UniFi Video Snapshot Getter]]
  • infrastructure/services/unifisnapshotgetter.1565918084
  • Last modified: 4 years ago
  • (external edit)
