infrastructure:services:verdaccio [2020/07/15 14:24] jabelone |
infrastructure:services:verdaccio [2020/07/15 15:26] jabelone |
====== Verdaccio ====== | ====== Verdaccio ====== | ||
- | HSBNE has an instance of [[https://github.com/verdaccio/verdaccio|Verdaccio]] running which caches commonly used npm modules to allow faster and more reliable downloads. Please contact a maintainer for access details. | + | HSBNE has an instance of [[https://github.com/verdaccio/verdaccio|Verdaccio]] running which caches commonly used npm modules to allow faster and more reliable downloads. |
+ | To use HSBNE's verdaccio instance, either set your registry to use it with: | ||
+ | <code ->npm set registry https://npm.hsbne.org</code> | ||
+ | or use it on a per command basis with | ||
+ | <code>NPM_CONFIG_REGISTRY=https://npm.hsbne.org npm i</code> | ||
=== Useful Info === | === Useful Info === |
- infrastructure/services/verdaccio
- by jabelone
