tools:automotive:jackstands [2020/09/30 02:03] blufires Formatting |
tools:automotive:jackstands [2020/09/30 03:27] blufires moved picture |
Line 3: | Line 3: | ||
HSBNE has many pairs of jack stands in both the screw and ratcheting types. | HSBNE has many pairs of jack stands in both the screw and ratcheting types. | ||
+ | {{:tools:automotive:jackstands.jpg?400|}} | ||
Use a jack on a safe jacking point to lift a vehicle, then place a jack stand under another safe jacking point and adjust it to the maximum height under that point. Lower the jack so that the vehicle comes to rest on the jack stand. | Use a jack on a safe jacking point to lift a vehicle, then place a jack stand under another safe jacking point and adjust it to the maximum height under that point. Lower the jack so that the vehicle comes to rest on the jack stand. | ||
- | ===== Usage ===== | + | ===== Safety tips ===== |
* Only work on hard, level ground. | * Only work on hard, level ground. | ||
* Care should be taken to find a safe part of the vehicle to support its weight upon the stand and the jack, such as K frames, axles and designated jacking points. Placing jacks or stands under a weak part of the vehicle may cause the jack or stand to puncture the underide of the vehicle, causing damage and risking serious injury. Designated jacking points will be identified in the vehicle's owner's manual. | * Care should be taken to find a safe part of the vehicle to support its weight upon the stand and the jack, such as K frames, axles and designated jacking points. Placing jacks or stands under a weak part of the vehicle may cause the jack or stand to puncture the underide of the vehicle, causing damage and risking serious injury. Designated jacking points will be identified in the vehicle's owner's manual. | ||
Line 15: | Line 16: | ||
* If you're at all unsure, ask for help on the Automotive Cause Discord channel before using jack stands. Lifting a car incorrectly is very dangerous. | * If you're at all unsure, ask for help on the Automotive Cause Discord channel before using jack stands. Lifting a car incorrectly is very dangerous. | ||
- | {{:tools:automotive:jackstands.jpg?400|}} | ||
- tools/automotive/jackstands
- by geoffc
