tools:automotive:jackstands [2020/09/30 02:03] blufires Typo |
tools:automotive:jackstands [2020/09/30 20:11] blufires switched to nicer photo |
Line 3: | Line 3: | ||
HSBNE has many pairs of jack stands in both the screw and ratcheting types. | HSBNE has many pairs of jack stands in both the screw and ratcheting types. | ||
+ | {{:tools:automotive:stands.jpg?400|}} | ||
Use a jack on a safe jacking point to lift a vehicle, then place a jack stand under another safe jacking point and adjust it to the maximum height under that point. Lower the jack so that the vehicle comes to rest on the jack stand. | Use a jack on a safe jacking point to lift a vehicle, then place a jack stand under another safe jacking point and adjust it to the maximum height under that point. Lower the jack so that the vehicle comes to rest on the jack stand. | ||
Line 15: | Line 16: | ||
* If you're at all unsure, ask for help on the Automotive Cause Discord channel before using jack stands. Lifting a car incorrectly is very dangerous. | * If you're at all unsure, ask for help on the Automotive Cause Discord channel before using jack stands. Lifting a car incorrectly is very dangerous. | ||
- | {{:tools:automotive:jackstands.jpg?400|}} | ||
- tools/automotive/jackstands
geoffc
