tools:craftpunk:dremel_station [2020/04/11 12:01] 127.0.0.1 external edit |
tools:craftpunk:dremel_station [2020/12/13 15:29] docforrest |
Line 7: | Line 7: | ||
- plans for installation | - plans for installation | ||
- how to responsibly use | - how to responsibly use | ||
+ | | Aliases | "Dremel 3000" "Jewellery Dremel" |<WRAP> | ||
+ | //[[https://snipe.hsbne.org/|Asset Register]]// | ||
+ | //[[https://xero.com/|Xero Asset]]// | ||
+ | //[[https://portal.hsbne.org/|Portal]]// | ||
+ | [[https://forum.hsbne.org/search?q=dremel_station|Forum Posts]] | ||
+ | </WRAP>| | ||
+ | | Official Maintainer | TBD | | ||
+ | <WRAP clear></WRAP> | ||
+ | ===== Current Status ===== | ||
+ | <WRAP safety half round> | ||
+ | === Maintenance === | ||
+ | Machine is working as expected. | ||
+ | ===== Usage ===== | ||
+ | <WRAP half round info > | ||
+ | **This machine does not require induction further than reading (TO BE WORKED ON).** | ||
+ | <WRAP column half> | ||
+ | | Recommended | {{:resources:ppe-wearhandprotection.gif?100&nolink}} | We recommend cut-resistant gloves. | | ||
+ | | Recommended | {{:resources:ppe-weargoggle.gif?100&nolink}} | Please wear goggles or a face shield when operating tool | | ||
+ | | Required | {{:resources:ppe-wearenclosedshoes.gif?200&nolink}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
+ | ^ Name ^ Value ^ | ||
+ | === Manufacturer === | ||
+ | * E | ||
+ | * P | ||
+ | * http://www.dremel.com.au | ||
+ | === Reseller/Maintenance === | ||
+ | === Known Identical Models === | ||
+ | ^ Date ^ Description ^ Workaround ^ Proposed Remediation ^ | ||
+ | ===== Maintenance ===== | ||
+ | ^ Interval ^ Task ^ | ||
+ | ===== RACI ===== | ||
+ | PLACEHOLDER A RACI is an important documentation process to let people know what ACTIONS can happen, and who needs to be Responsible, Accountable, Consulted and Informed for each ACTION. Delete this line. | ||
+ | <WRAP column third> | ||
+ | | Modification and Repairs | - | AC | C | I | I | I | R | | ||
+ | PLACEHOLDER: Risk assessment is important to ensure we are making tools available to members in a responsible fashion. Please make every effort to do a reasonable risk assessment. If there is a safety incident with the tool, please redo a risk assessment and add it to the table. | ||
+ | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| | ||
+ | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | ||
+ | PLACEHOLDER: A decision register is for general documentation when some decision is made regarding the tool. To change its location, mode of operation, to buy an accessory, to replace something, to change how it operates etc. Delete this line. | ||
- tools/craftpunk/dremel_station
- by docforrest
