tools:craftpunk:kiln [2020/10/05 12:05] eris [Documents] |
tools:craftpunk:kiln [2020/11/26 19:20] eris [Recommended PPE] |
Line 25: | Line 25: | ||
- | Currently under maintenance until 7/10/2020 | + | <WRAP danger half round> |
+ | === Maintenance === | ||
+ | Machine is undergoing upgrades and can't be used. | ||
- | PLACEHOLDER: Pick one of these three and delete this line. | + | |
**This machine <wrap hi>requires induction unless you are having an inducted person fire it for you</wrap>.** | **This machine <wrap hi>requires induction unless you are having an inducted person fire it for you</wrap>.** | ||
Line 34: | Line 39: | ||
- | [[draw.io|draw.io]] | + | |
{{:tools:craftpunk:kiln-inductionflow.png?400|}} | {{:tools:craftpunk:kiln-inductionflow.png?400|}} | ||
Line 59: | Line 64: | ||
- | PLACEHOLDER: There is a large collection of PPE Icons in the "resources" folder. Please update these two columns with appropriate PPE recommendations. Columns of the tables are "Recommended/Required/Warning/Maintenance", PPE Icon and Description. Delete this line. | + | |
Line 112: | Line 117: | ||
- | ^ Date ^ Description ^ Workaround ^ Proposed Remediation ^ | + | ^ Date ^ Description ^ Workaround ^ Proposed Remediation ^ |
- | | 03/10/2020 | Relined 3/10/20 | Wait for kiln to dry and be tested electrically and test fired | testfire to happen 06/10/2020 | | + | | | | | | |
- | | 03/10/2020 | Element wearing out | keep kiln below 1200°C until elements replaced - approved by vote 15/09/2020 | Eris to replace elements Electrician to approve | | + | | 03/10/2020 | Element wearing out | keep kiln below 1200°C until elements replaced - approved by vote 15/09/2020 | Eris to replace elements Electrician to approve | |
- | | 01/01/2018 | Eris | Kiln dried, cleaned, patched, rewired with SSR and extra safety devices | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack | ~$200 | | + | | 01/01/2018 | Eris | Kiln dried, cleaned, patched, rewired with SSR and extra safety devices | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack | ~$200 | |
+ | | 03/10/2020 | Eris | Waited for kiln to dry and be tested electrically and test fired Relined 3/10/20 | testfired to 200°C 06/10/2020 8MΩ to ground. | | | ||
in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack. | Approved by vote ~$200 | | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack. | Approved by vote ~$200 | | ||
- tools/craftpunk/kiln
- by eris
