tools:craftpunk:kiln [2020/10/19 11:24] eris [Table] |
tools:craftpunk:kiln [2020/11/26 19:20] eris [Recommended PPE] |
Line 25: | Line 25: | ||
- | <WRAP safety half round> | + | <WRAP danger half round> |
- | === Working === | + | === Maintenance === |
- | Machine is working as expected. | + | Machine is undergoing upgrades and can't be used. |
Line 64: | Line 64: | ||
- | There is a large collection of PPE Icons in the "resources" folder. Please update these two columns with appropriate PPE recommendations. Columns of the tables are "Recommended/Required/Warning/Maintenance", PPE Icon and Description. Delete this line. | + | |
Line 124: | Line 124: | ||
| 01/01/2018 | Eris | Kiln dried, cleaned, patched, rewired with SSR and extra safety devices | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack | ~$200 | | | 01/01/2018 | Eris | Kiln dried, cleaned, patched, rewired with SSR and extra safety devices | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack | ~$200 | | ||
- | | 03/10/2020 | Eris | Waited for kiln to dry and be tested electrically and test fired Relined 3/10/20 | testfired to 200°C 06/10/2020 | | | + | | 03/10/2020 | Eris | Waited for kiln to dry and be tested electrically and test fired Relined 3/10/20 | testfired to 200°C 06/10/2020 8MΩ to ground. | | |
in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack. | Approved by vote ~$200 | | in series are lid switch, second controller to limit temp to 1250°C, 24vdc plugpack. | Approved by vote ~$200 | | ||
- tools/craftpunk/kiln
- by eris
