tools:digitalfabrication:3dprinters:home [2020/08/26 18:49] jabelone [Octoprint Configurations] |
tools:digitalfabrication:3dprinters:home [2021/11/18 18:05] jdownie [3D Printer Maintainers] |
+ | ==== PETG ==== | ||
+ | ==== ABS ==== | ||
+ | ==== ASA ==== | ||
+ | To get started printing something, you must read the printer's individual page *in full*. Please don't try to just "work it out" or you can damage the machine. | ||
- | <del> | ||
bwilkins
