tools:digitalfabrication:3dprinters:home [2020/08/26 18:49] jabelone [Octoprint Configurations] |
tools:digitalfabrication:3dprinters:home [2023/04/26 05:17] (current) bwilkins [3D Printers] |
+ | ==== PETG ==== | ||
+ | ==== ABS ==== | ||
+ | ==== ASA ==== | ||
- | ==== Octoprint Configurations ==== | + | |
- | Octoprint is set up on each machine to use Cura as its slicer. | + | |
- | <del> | + | |
- | The slicing profiles for each machine are stored in their own **branches** in this github repo: | + | |
- | [[https://github.com/HSBNE/RepRap-Configurations|Configuration files for our 3D printers]]</del> | + | |
- | This used to be the case but hasn't been updated in a while. If you'd like to fix this please let us know! | + | |
- by bwilkins
