tools:digitalfabrication:3dprinters:home [2020/01/18 15:45] |
tools:digitalfabrication:3dprinters:home [2023/04/26 05:17] bwilkins [3D Printers] |
- | Never leave any filament 3D printer running unattended. They are all capable of burning down HSBNE if something goes wrong. | + | Never leave any filament 3D printer running unattended. The entire bench and print area must be 100% clear of debris and tools. DO NOT start a print before checking this. |
- | ==== 3D Printer Experts ==== | + | ===== Want to get started printing quickly? ===== |
- | These people know the ins and outs of 3D printing and are generally happy to help out when needed: | + | Unfortunately, there is no way to get started quickly. If you try to skip any steps or don't ready everything you're meant to, you will **most likely damage something**. Please read this entire page, then click on the printer you want to use, and read that entire page. |
- | * Steph Piper (@sjpiper145) | + | ===== Using Filament ===== |
- | * Brendan Halliday (@nogthree) | + | {{ :tools:digitalfabrication:3dprinters:filament.jpg?nolink&400}} |
- | * Aaron Bycroft (@Sgt.Dicks) | + | It is expected that you pay for any filament that you use for the 3D printers. Octoprint will automatically calculate the time taking into account the estimate print time, and filament usage. The below filaments are compatible with our printers. If you have been authorised to use your own slicer, please use an approximate cost of $40/kg of filament when calculating the cost. If you've been authorised to use your own filament, please donate approx $2/hr for printer usage and maintenance. |
- | * Jaimyn Mayer (@jabelone) (currently not available to assist) | + | |
- | If you consider yourself in the know, add yourself to the list! (but ask one of us first so we can keep track) | + | ==== PLA ==== |
- | <nspages -exclude:home -usePictures -h1 -textNS="HSBNE's Printer Fleet" -subns -pagesInNs -naturalOrder> | + | PLA is recommended for it's ease of printing whenever you don't need the strength or heat resistance of PETG. |
+ | ==== PETG ==== | ||
+ | ==== ABS ==== | ||
+ | ==== ASA ==== | ||
- | ===== HSBNE 3D Printer Design Tips ====== | + | ===== 3D Printer Maintainers ===== |
+ | These people know the ins and outs of 3D printing and are generally happy to help out when needed: | ||
+ | * Brett Wilkins (@Bugg) | ||
+ | * David Jericho (@Woofybean) | ||
+ | If you consider yourself in the know, add yourself to the list! (but ask one of us first so we can keep track) | ||
+ | ===== HSBNE Design Tips ====== | ||
- | When using the 3D printers it helps the maintainers if you clean the bed when you're done, a wipe-down with some IPA will clean the bed on the Taz, the chang-yi i3 and the space-i2. On the pelrun-i2 you will need to speak to James as this is his personal machine on loan to HSBNE. | + | |
- | Try not to leave any debris or print detritus around the printers too, as they may get caught up in the mechanical parts, and mess attracts more mess. Don't see a profile that works for your printing needs? Check out the Octoprint Configurations below. | + | |
- | ===== 3d Printers ===== | + | |
- | ==== Space Taz 5 ==== | + | |
- | {{:tools:taz5.jpg?direct&300|}} | + | |
- | **Internal Address:** http://space-taz5.hsbne.org/ (http://10.0.1.154/) | + | |
- | **Maintainers:** Drew Spriggs | + | |
- | ==== Left CR-10 ==== | + | |
- | {{:tools:cr-10.jpg?direct&300|}} | + | |
- | **Internal Address:** http://left-cr10.hsbne.org/ (http://10.0.1.152/) | + | |
- | ==== Right CR-10 ==== | + | When using the 3D printers it helps the maintainers if you clean the bed when you're done, a wipe-down with some IPA (isopropyl alcohol) will clean the bed on the Taz. A scraper works well at removing old bits of glue, hairspray, etc from the heated bed of the Creality (CR-X and CR-10) machines. Please be careful as even blunt edges of a tool can cut! |
- | {{:tools:cr-10.jpg?direct&300|}} | + | Try not to leave any debris or print detritus around the printers too, as they may get caught up in the mechanical parts, and mess attracts more mess. |
- | **Internal Address:** http://right-cr10.hsbne.org/ (http://10.0.1.153/) | + | To get started printing something, you must read the printer's individual page **in full**. |
- | **Maintainers:** Drew Spriggs | + | __Please don't try to just "work it out" or you can damage the machine.__ |
- | ==== Octoprint Configurations ==== | + | <nspages -exclude:home -usePictures -h1 -textNS="" -subns -pagesInNs -naturalOrder> |
- | Octoprint is set up on each machine to use Cura as its slicer. | + | |
- | The slicing profiles for each machine are stored in their own **branches** in this github repo: | + | ===== Other Notes ===== |
- | [[https://github.com/HSBNE/RepRap-Configurations|Configuration files for our 3D printers]] | + | |
==== Cron Job ==== | ==== Cron Job ==== |
- by bwilkins
