tools:digitalfabrication:3dprinters:home [2020/01/19 19:35] |
tools:digitalfabrication:3dprinters:home [2020/08/26 18:49] jabelone [Octoprint Configurations] |
Line 43: | Line 43: | ||
==== Octoprint Configurations ==== | ==== Octoprint Configurations ==== | ||
Octoprint is set up on each machine to use Cura as its slicer. | Octoprint is set up on each machine to use Cura as its slicer. | ||
+ | <del> | ||
The slicing profiles for each machine are stored in their own **branches** in this github repo: | The slicing profiles for each machine are stored in their own **branches** in this github repo: | ||
- | [[https://github.com/HSBNE/RepRap-Configurations|Configuration files for our 3D printers]] | + | [[https://github.com/HSBNE/RepRap-Configurations|Configuration files for our 3D printers]]</del> |
+ | This used to be the case but hasn't been updated in a while. If you'd like to fix this please let us know! | ||
- by bwilkins
