tools:digitalfabrication:3dprinters:home [2020/09/27 20:58] jabelone |
tools:digitalfabrication:3dprinters:home [2020/09/29 18:59] jabelone |
======= 3D Printers ======= | ======= 3D Printers ======= | ||
- | {{:tools:digitalfabrication:3dprinters:printers.jpg?nolink&400|}} | + | {{:tools:digitalfabrication:3dprinters:printers.jpeg?nolink&400}} |
Never leave any filament 3D printer running unattended. | Never leave any filament 3D printer running unattended. | ||
Line 7: | Line 7: | ||
- | ==== Using Filament ==== | + | ===== Using Filament ===== |
- | If you're using our 3D printer filament please read [[https://wiki.hsbne.org/tools/digitalfabrication/3dprinters/filament|this page]] first. | + | {{ :tools:digitalfabrication:3dprinters:filament.jpg?nolink&400}} |
- | ==== 3D Printer Experts ==== | + | ==== ABS ==== |
+ | We do not recommend people print with this as PETG is a generally a better alternative for most situations. ABS is very strong and has high heat tolerance. It has a glass transition temperature of around 100 degrees which means this is when it gets soft. However, it's plagued by warping problems and is notoriously difficult to print with. | ||
+ | ==== PETG ==== | ||
+ | PETG is recommended over ABS as it's nearly as strong but has slightly less heat resistance. It's much easier to print with and does not normally have printing or warping issues. It has a glass transition temperature of around 80 degrees. | ||
+ | ==== PLA ==== | ||
+ | PLA is the most brittle and weak of filaments and also has a fairly low glass transition temperature of around 60 degrees. PLA is recommended for it's ease of printing whenever you don't need the strength or heat resistance of PETG. | ||
+ | ===== 3D Printer Experts ===== | ||
* Brendan Halliday (@nogthree) | * Brendan Halliday (@nogthree) |
- by bwilkins
