tools:electronics:soldering [2016/07/02 17:17] |
tools:electronics:soldering [2020/09/16 17:21] catprog Start of instructions. |
+ | ====== Soldering Irons ====== | ||
HSBNE has a multitude of Soldering Irons for various different needs. | HSBNE has a multitude of Soldering Irons for various different needs. | ||
- | ====== Yihua 936 Soldering Iron ====== | + | ====== Thermaltronics TMT-2000S-K ====== |
+ | {{:tools:electronics:tmt2000s.jpg?nolink&400|}} | ||
+ | We have two of these stations with SHP-K handpieces. It takes the K type Thermaltronics tips. | ||
+ | To Use: | ||
+ | 1)Make sure the black button up top is down. | ||
+ | 2)The black switch below is set to the correct socket | ||
+ | 3)Lift the soldering iron out of the holder | ||
+ | 4)Make sure the light turns yellow. | ||
+ | To change tips | ||
+ | 1) Turn off the soldering iron | ||
+ | 2)Use the silicon pad to pull the tip out | ||
+ | 3) Insert new tip | ||
+ | 4) Turn soldering iron on and make sure the light turns yellow. | ||
====== Metcal PS-200 Soldering Iron ====== | ====== Metcal PS-200 Soldering Iron ====== | ||
- | ====== Sansai PE-845D 1304 Trigger Iron ====== | + | |
- | {{:tools:sansaipe845d.jpg?200|}} | + | {{tag>electronics}} |
- tools/electronics/soldering
- by catprog
