tools:home [2019/07/21 14:06]
tools:home [2022/09/30 09:13]
capella_ben [Metal Shop]
Line 1: Line 1:
-===== HSBNE'​s ​Tools =====+===== HSBNE Tools =====
-Tools documents ​the various ​things ​HSBNE operates, small to big. Laser Cutters, 3d Printers, PCB Etchers, Mills, Lathes, Saws, it all goes here. It is grouped by the area it is located in.+This page lists the various ​tools and machines available for HSBNE members ​to use. Laser Cutters, 3d Printers, Mills, Lathes, Saws, etc.; it all goes here. This page is grouped by HSBNE cause areas. The standard template for adding new tool pages can be found [[tools:​template|here]].
-==== Areas ====+===== Add New Tool =====
-=== Classroom ===+Any registered wiki user can create a new tool page by using the form below (only visible to logged in users). Just select the cause area, enter the name of the tool, then click "Add page".
-<nspages tools:​classroom -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}" -naturalOrder>​+{{NEWPAGE>​tools}}
-=== Craft Punk ===+\\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems).
-Overseen by the [[:​causes:​craftpunk|Craft Punk Cause]]<nspages tools:​craftpunk -subns -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}"​ -naturalOrder>​+2) Check this list to make sure the page you want to add doesn'​t already exist.
-=== Digital Fabrication ===+3) If the page doesn'​t exist, you can create a new one by filling out the form above.
-Overseen by the [[:​causes:​digitalfabrication|Digital Fabrication Cause]]. <nspages tools:​digitalfabrication -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="{{:​wiki:​logo.png}}" -naturalOrder>​+4) Once you've clicked ​the "Add page" ​button you will see a new page pre-filled with the HSBNE Tool Page template. You should modify this with the information of the tool.
-=== Green Room ===+5) Once you are done, click the green "​Save"​ button at the bottom of the page to publish it.
-<nspages tools:​greenroom -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}"​ -naturalOrder>​+===== Documenting Tools on this Wiki =====
-=== Electronics Bench ===+Most tools use our tool template so that we have a consistent approach to documenting our tools and machines. On these tool pages, you'll see a green/​amber/​red notice box at the top of the page showing the tools current operational status. Directly below this, you'll see the "​Usage"​ area which includes instructions on how to get inducted, how to get started with using the machine, and any important notes.
-Overseen by the [[:causes:​electronics|Electronics Cause]]. <​nspages ​tools:electronics ​-exclude:​home ​-usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}" -naturalOrder>​+{{:tools:tool-induction-section.png?400|}}
-=== Forge ===+==== Other pages ====
-<nspages tools:forge -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:logo.png}}" -naturalOrder>​+If you come across a tool wiki page that doesn'​t use our tool template, it may not have detailed usage/​induction instructions. In these cases, please contact the cause that maintains the tool via their channel in Discord, or on our membership forum [[https://​forum.hsbne.org|here]]. The most common way to get inducted with these tools is to organise an induction directly with a cause volunteer, but it varies, so be sure to ask.
-=== Metal Shop ===+===== Mechanical =====
-Overseen by the [[:​causes:​metalworking|Machine Shop Cause]]. ​<nspages tools:metalshop ​-exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku> ​-textPages=_ckgdoku_QUOT__ckgdoku> ​-subns -pagesInNs ​-defaultPicture="​{{:​wiki:​logo.png}}" ​-naturalOrder>​+<nspages tools:mechanical ​-exclude:​home -usePictures -h1 -textNS="" ​-textPages="" ​-subns -pagesInNs -naturalOrder>​
-=== Wood Shop ===+\\ \\
-Overseen by the [[:​causes:​woodworking|Woodworking Cause]]. <nspages tools:​woodshop -exclude:​home -usePictures -h1 -textNS=_ckgdoku_QUOT__ckgdoku>​ -textPages=_ckgdoku_QUOT__ckgdoku>​ -subns -pagesInNs -defaultPicture="​{{:​wiki:​logo.png}}"​ -naturalOrder>​+===== Blacksmithing & Casting =====
 +<nspages tools:​blacksmithing -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Craft Punk =====
 +Overseen by the [[causes/​craftpunk|Craft Punk Cause]]. <nspages tools:​craftpunk -subns -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Digital Fabrication =====
 +Overseen by the [[causes/​digitalfabrication|Digital Fabrication Cause]]. <nspages tools:​digitalfabrication -r -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Electronics Bench =====
 +Overseen by the [[causes/​electronics|Electronics Cause]]. <nspages tools:​electronics -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Metal Shop =====
 +Overseen by the [[causes/​metalworking|Metal Shop Team]]. <nspages tools:​metalshop -exclude:​home -exclude:​yaglaser -exclude:​wip:​ -exclude:​handtools:​ -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Wood Shop =====
 +Overseen by the [[causes/​woodworking|Woodworking Cause]]. <nspages tools:​woodshop -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
 +===== Infrastructure =====
 +Overseen by the [[causes/​infrastructure|Infrastructure Cause]]. <nspages tools:​infrastructure -exclude:​home -usePictures -h1 -textNS=""​ -textPages=""​ -subns -pagesInNs -naturalOrder>​
  • tools/home
  • Last modified: 21 months ago
  • by capella_ben
