Next revision | Previous revision Next revision Both sides next revision | ||
tools:home [2020/04/11 12:01] 127.0.0.1 external edit |
tools:home [2022/08/12 10:22] unmeg |
+ | ===== Add New Tool ===== | ||
- | ==== Areas ==== | + | Any registered wiki user can create a new tool page by using the form below (only visible to logged in users). Just select the cause area, enter the name of the tool, then click "Add page". |
- | === Automotive === | + | {{NEWPAGE>tools}} |
+ | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). | ||
- | === Blacksmithing === | ||
- | === Craft Punk === | + | \\ \\ |
- | <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | ===== Craft Punk ===== |
- | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | + | Overseen by the [[causes/craftpunk|Craft Punk Cause]]. <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
- | <nspages tools:digitalfabrication -r -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
+ | Overseen by the [[causes/metalworking|Machine Shop Cause]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
- | === Electronics Bench === | + | ===== Infrastructure ===== |
- | === Forge === | + | Overseen by the [[causes/infrastructure|Infrastructure Cause]]. <nspages tools:infrastructure -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
- | <nspages tools:forge -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Wood Shop === | + | |
- | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | **Add a Tool | + | \\ \\ |
- | **{{NEWPAGE>@NS@}} | + |
