tools:home [2021/10/06 12:03] ryan6338 [Metal Shop] |
Line 9: | Line 9: | ||
- | \\ 1) Login using your HSBNE Wiki account (see Jaimyn if you have any problems). | + | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). |
Line 19: | Line 19: | ||
Line 51: | Line 61: | ||
- | Overseen by the [[causes/metalworking|Machine Shop Cause]]. <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -pagesInNs -naturalOrder> | + | Overseen by the [[causes/metalworking|MetalShop Team]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
capella_ben
