tools:home [2021/11/06 06:59] antifoo |
tools:home [2022/08/12 10:22] unmeg |
Line 9: | Line 9: | ||
- | \\ 1) Login using your HSBNE Wiki account (contact @infrustructure on discord if you have any problems). | + | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). |
Line 19: | Line 19: | ||
<nspages tools:blacksmithing -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | <nspages tools:blacksmithing -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
