tools:home [2020/01/18 15:34] |
+ | ===== Add New Tool ===== | ||
- | ==== Areas ==== | + | Any registered wiki user can create a new tool page by using the form below (only visible to logged in users). Just select the cause area, enter the name of the tool, then click "Add page". |
- | === Automotive === | + | {{NEWPAGE>tools}} |
- | === Classroom === | + | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). |
- | <nspages tools:classroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Craft Punk === | + | 2) Check this list to make sure the page you want to add doesn't already exist. |
- | <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | + | |
- | <nspages tools:digitalfabrication -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Green Room === | + | 3) If the page doesn't exist, you can create a new one by filling out the form above. |
- | <nspages tools:greenroom -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Electronics Bench === | + | |
- | === Forge === | + | 4) Once you've clicked the "Add page" button you will see a new page pre-filled with the HSBNE Tool Page template. You should modify this with the information of the tool. |
- | <nspages tools:forge -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Metal Shop === | + | 5) Once you are done, click the green "Save" button at the bottom of the page to publish it. |
- | <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | ===== Documenting Tools on this Wiki ===== |
- | === Wood Shop === | + | |
- | Overseen by the [[causes/woodworking|Woodworking Cause]]. | + | Most tools use our tool template so that we have a consistent approach to documenting our tools and machines. On these tool pages, you'll see a green/amber/red notice box at the top of the page showing the tools current operational status. Directly below this, you'll see the "Usage" area which includes instructions on how to get inducted, how to get started with using the machine, and any important notes. |
- | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
+ | Overseen by the [[causes/metalworking|Metal Shop Team]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
