Both sides previous revision Previous revision | Next revision Both sides next revision | ||
tools:home [2022/06/21 15:21] wixted |
tools:home [2022/08/12 10:22] unmeg |
Line 29: | Line 29: | ||
If you come across a tool wiki page that doesn't use our tool template, it may not have detailed usage/induction instructions. In these cases, please contact the cause that maintains the tool via their channel in Discord, or on our membership forum [[https://forum.hsbne.org|here]]. The most common way to get inducted with these tools is to organise an induction directly with a cause volunteer, but it varies, so be sure to ask. | If you come across a tool wiki page that doesn't use our tool template, it may not have detailed usage/induction instructions. In these cases, please contact the cause that maintains the tool via their channel in Discord, or on our membership forum [[https://forum.hsbne.org|here]]. The most common way to get inducted with these tools is to organise an induction directly with a cause volunteer, but it varies, so be sure to ask. | ||
- | ===== Automotive ===== | + | ===== Mechanical ===== |
- | <nspages tools:automotive -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | <nspages tools:mechanical -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
