tools:woodshop:bandsaw [2021/01/10 20:49] duncang Added PPE |
tools:woodshop:bandsaw [2022/05/03 19:26] ale [Induction] |
Line 48: | Line 48: | ||
- | In order to get inducted on this machine you need to contact the cause leader (Ale Moré on discord) and convene a time to make the induction. | + | This machine's induction, as some others in the woodshop, is organized through a [[https://forum.hsbne.org/search?q=inductions%20between%20%23cause-effect%3Awoodworking%20order%3Alatest|forum post]]. In the following link, you will find more information about it. [[teams:woodworking:getting_around#what_machines_require_induction|Getting around - Inductions]] |
+ | ==== Guidelines ==== | ||
- | Unofficially we are giving at least one induction per fortnight (commonly there's more than one though) every other Tuesday, from 6pm to 7pm before the table saw assesments. | + | === What's this tool for? === |
+ | In general terms this machine will allow you to cut wood and wood like materials. Particularly is good when you want to cut curves and resawing timber. | ||
+ | === What’s Resawing? === | ||
+ | Strictly, resawing is a type of rip cut (cut along the grain) but across the thickness. In other words, is a cut that will give a workpiece with the same width and length but a reduced thickness. | ||
+ | In general terms, resawing could refer widely to downsizing timber. A bandsaw is good at this because it has a thing kerf compared to a table saw and it’s way more safe and forgiving than a table saw when it comes to deal with rough lumber (e.g. cup, bow, twist timber). | ||
+ | === What can I cut with it? === | ||
+ | You can cut solid wood, engineered wood (MDF, Chipboard, Plywood, CLT, OSB) and some composite materials. | ||
+ | Before cutting any composite material (e.g., Plastics, resin-based materials) we ask you to talk to the woodworking cause leader about it. | ||
+ | === What I can’t cut with it? === | ||
+ | Any materials that contain glass, carbon or Kevlar fibres can’t be cut on this machine. | ||
- | Inductions will be coordinated via {{https://www.eventbrite.com.au/o/hsbne-inc-4654630925|Eventbrite}} | ||
- | ==== Guidelines ==== | ||
- | PLACEHOLDER: This is where you can document the usage practices for the machine generally. If this section gets very long, then it should be part of a canvas course for induction. Don't document maintenance procedures here, please do that below in the maintenance section. Delete this line. | ||
Line 82: | Line 96: | ||
| Saw blade length max | 4000mm | | | Saw blade length max | 4000mm | | ||
| Saw blade min width | 6mm | | | Saw blade min width | 6mm | | ||
+ | | Saw blade max width | 20mm | | ||
| Saw blade speed | 20m/min | | | Saw blade speed | 20m/min | | ||
| Wheel diameter | 440mm | | | Wheel diameter | 440mm | | ||
Line 98: | Line 113: | ||
- | * E sales@example.com | + | * Felder Group / Hammer |
- | * P 00 0000 0000 | + | * [[https://www.felder-group.com/en-au/products/bandsaws-c1958/bandsaw-classic-line-p144120]] |
- | * Mr. Re seller | + | For spare parts, contact: |
- | * Reseller Agencies | + | * Felder Australia |
- | * E sales@reseller.com | + | * Peter Burkitt |
- | * M 0000 000 000 | + | * E pb@felder.net.au |
- | === Known Identical Models === | + | Blades can also be purchased from Brisbane saw services. |
- | * Links to other machines that are a rebrand or similar | ||
Line 143: | Line 155: | ||
+ | ^ Date ^ Consumable ^ Comment ^ Member ^ | ||
+ | | 13/04/2021 | 10mm@4TPI General purpose blade | A new blade was opened and added to the working set. The old one was properly labelled and left to be used as a teaching tool. | Ale Moré | | ||
- tools/woodshop/bandsaw
