tools:woodshop:bandsaw [2021/02/13 16:24] ale [Induction] |
tools:woodshop:bandsaw [2022/05/03 19:26] (current) ale [Induction] |
Line 48: | Line 48: | ||
- | {{https://www.eventbrite.com.au/e/bandsaw-hammer-n4400-induction-tickets-135139364477|BandSaw inductions}} | + | |
- | In summary: | + | |
- | - Check this link to see if you can book an induction: {{https://www.eventbrite.com.au/e/bandsaw-hammer-n4400-induction-tickets-135139364477|BandSaw inductions}}. | + | |
Line 170: | Line 155: | ||
+ | ^ Date ^ Consumable ^ Comment ^ Member ^ | ||
+ | | 13/04/2021 | 10mm@4TPI General purpose blade | A new blade was opened and added to the working set. The old one was properly labelled and left to be used as a teaching tool. | Ale Moré | | ||
- tools/woodshop/bandsaw.1613197494
