tools:woodshop:cnc_sheet_router [2021/01/28 12:52] antifoo [Documents] |
tools:woodshop:cnc_sheet_router [2022/11/05 11:23] ale |
- | **PLACEHOLDER** | ||
- | **This is the template for a machine. Please copy and paste this to make new machine pages.** | ||
- | Please pay close attention, this template provides multiple options and placeholder text. You will need to select the correct option and replace all placeholder text. | ||
- | Please do not remove entire sections, they're there for a reason. | ||
- | Delete this box when you are done. | ||
{{:tools:woodshop:assembled_img_20210124_191109.jpg?400|}} | {{:tools:woodshop:assembled_img_20210124_191109.jpg?400|}} | ||
Line 16: | Line 4: | ||
====== Blue Elephant CNC Sheet Router ELE1325ATC-R "Bumblebee" (working title) ====== | ====== Blue Elephant CNC Sheet Router ELE1325ATC-R "Bumblebee" (working title) ====== | ||
- | | Aliases | "PLACEHOLDER", "Woodshop CNC" | | + | | Aliases |"Woodshop CNC" | |
| Other References |<WRAP> | | Other References |<WRAP> | ||
Line 27: | Line 15: | ||
</WRAP>| | </WRAP>| | ||
- | | Josh / Eris | PLACEHOLDER Please provide maintainer(s) name(s) | | + | | Maintainers | Ryan K, Josh H, Ale More | |
Line 33: | Line 21: | ||
- | PLACEHOLDER: Pick one of these three and delete this line. | ||
- | === Working === | ||
- | Machine is working as expected. | ||
<WRAP warning half round> | <WRAP warning half round> | ||
- | PLACEHOLDER Machine has some issue but is usable. please provide summary here | + | Machine is working. Please Contact Ryan Kirkpatrick or Ale More to use the machine. |
- | PLACEHOLDER NAME OF PERSON MARKING USABLE AND DATE | + | |
- | </WRAP> | + | |
- | <WRAP danger half round> | + | |
- | === Out of Order === | + | |
- | Machine is being commissioned. | + | |
- | Eris Ryan tagged it out 24/01/2021 | ||
- | **This machine <wrap hi>requires induction</wrap> to use.** | + | **This machine requires supervision to use.** |
+ | Using the CNC requires a much higher level of knowledge than most tools. The basic process is as follows: | ||
- | PLACEHOLDER: Please make a simple diagram using [[draw.io|draw.io]] to show induction process. Delete this line. | + | - Start with a computer model of the part (CAD) |
+ | - Create instructions (G-code) for the CNC controller (CAM) | ||
+ | - Cut out the part on the CNC | ||
- | {{:tools:woodshop:tablesaw-inductionflow.png?nolink|}} | + | If you don't have any familiarity with CNC work this video is a good place to start https://www.youtube.com/watch?v=YBGqknN3gGs. |
- | INSERT LINK TO ONLINE COURSE HERE | + | If you're struggling with the process or would like some guidance please reach out on Discord. |
- | Induction process is doing online video and quiz, then booking a time to do a practical exercise "making a speaker box". | ||
+ | ===== Postprocessors ===== | ||
+ | ==== Vectric ==== | ||
- | ==== Guidelines ==== | ||
- | PLACEHOLDER: This is where you can document the usage practices for the machine generally. If this section gets very long, then it should be part of a canvas course for induction. Don't document maintenance procedures here, please do that below in the maintenance section. Delete this line. | + | ==== Specifications ==== |
+ | ^ Item ^ Value ^ | ||
+ | | Post-processor | FANUC (Generic) | | ||
+ | | Spindle Max RPM | 18,000 | | ||
+ | | Spindle Taper | ISO 30 | | ||
+ | | Bed Size (mm) | X:1300 Y:2500 | | ||
+ | | 4th Axis Speed | 2000 deg/min | | ||
+ | | Automatic tool changer | Yes. Max 8 tools. | | ||
Line 101: | Line 89: | ||
<WRAP round download half left> | <WRAP round download half left> | ||
Line 118: | Line 103: | ||
- | <WRAP center round download half left > | + | <WRAP round download half left > |
==== Software ==== | ==== Software ==== | ||
Line 129: | Line 114: | ||
https://drive.google.com/drive/folders/1gGaesrOJUUI9Nfo9VuVv5VRvlFOpksIS?usp=sharing | https://drive.google.com/drive/folders/1gGaesrOJUUI9Nfo9VuVv5VRvlFOpksIS?usp=sharing | ||
+ | <WRAP clear></WRAP> | ||
- | <WRAP center round download half right> | + | <WRAP round download half right> |
==== Vacuum Pump Manual ==== | ==== Vacuum Pump Manual ==== | ||
Line 184: | Line 170: | ||
^ Image ^ Category ^ Accessory Name & Notes ^ Location ^ Buy from ^ | ^ Image ^ Category ^ Accessory Name & Notes ^ Location ^ Buy from ^ | ||
| PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | ||
- | | {{:tools:woodshop:way_lubricants-l500.png?400}} | liquid consumable | Way oil, for storage tank delivery system | Corner locked storage cupboard | https://www.ebay.com.au/itm/124068121688?chn=ps&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&itemid=124068121688&targetid=1137076995982&device=c&mktype=pla&googleloc=9068947&poi=&campaignid=10101784988&mkgroupid=102311921740&rlsatarget=pla-1137076995982&abcId=9300367&merchantid=7364522&gclid=CjwKCAiA9bmABhBbEiwASb35VzR-Wu-bG333kZm-uArTLnGKFkF_d6n50pyumdwsj5b4Bh1LEAIgBRoCCUEQAvD_BwE | | + | | {{:tools:woodshop:way_lubricants-l500.png?400}} | liquid consumable | Way oil, for storage tank delivery system | Corner locked storage cupboard | [[https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=Mill+or+Lathe+Way+Oil+1L+ISO+68+-+Slideway+Oil+with+EP+friction+modifier&_sacat=0|Way Lubricant Mill or Lathe Oil 1 litre (ebay)]] | |
- | | {{:tools:woodshop:tool_lubricant_air_mix_s-l1600.jpg?400}} | liquid consumable | tool/air oil, for storage tank delivery system | Corner locked storage cupboard | https://www.ebay.com.au/itm/Air-Tool-Lubricant-Oil-Sonsbeek-1-Litre/153620612985?hash=item23c4808779:g:SzoAAOSwZ75dZbCN&frcectupt=https://www.ebay.com.au/itm/Air-Tool-Lubricant-Oil-Sonsbeek-1-Litre/153620612985?hash=item23c4808779:g:SzoAAOSwZ75dZbCN&frcectupt=true | | + | | {{:tools:woodshop:tool_lubricant_air_mix_s-l1600.jpg?400}} | liquid consumable | tool/air oil, for storage tank delivery system | Corner locked storage cupboard | [[https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=Air-Tool-Lubricant-Oil-Sonsbeek-1-Litre&_sacat=0|Sonsbeek Air Tool Lubricant 1 Litre (ebay)]] | |
| Electricity | on demand consumable | 3 phase power with tool turn on and use | n/a | vacuum pump 5.5kwHrs/60 min use, INSERT OTHER USE HERE | | | Electricity | on demand consumable | 3 phase power with tool turn on and use | n/a | vacuum pump 5.5kwHrs/60 min use, INSERT OTHER USE HERE | | ||
Line 193: | Line 179: | ||
- | ===== RACI ===== | ||
- | PLACEHOLDER A RACI is an important documentation process to let people know what ACTIONS can happen, and who needs to be Responsible, Accountable, Consulted and Informed for each ACTION. Delete this line. | ||
- | <WRAP column third> | ||
- | | Modification and Repairs | - | AC | C | I | I | I | R | | ||
- | <WRAP clear></WRAP> | ||
- | PLACEHOLDER: Risk assessment is important to ensure we are making tools available to members in a responsible fashion. Please make every effort to do a reasonable risk assessment. If there is a safety incident with the tool, please redo a risk assessment and add it to the table. | ||
- | | 0001 | PLACEHOLDER DEATH | Intolerable | Probable | 11 | PLACEHOLDER Induction to train users in correct usage | Low | Improbable | 1 | | ||
===== Decision Register ===== | ===== Decision Register ===== |
- tools/woodshop/cnc_sheet_router
