tools:woodshop:cnc_sheet_router [2021/01/28 13:09] antifoo [Risk Matrix and Mitigation] added risks |
tools:woodshop:cnc_sheet_router [2022/11/05 11:19] ale |
- | **PLACEHOLDER** | ||
- | **This is the template for a machine. Please copy and paste this to make new machine pages.** | ||
- | Please pay close attention, this template provides multiple options and placeholder text. You will need to select the correct option and replace all placeholder text. | ||
- | Please do not remove entire sections, they're there for a reason. | ||
- | Delete this box when you are done. | ||
{{:tools:woodshop:assembled_img_20210124_191109.jpg?400|}} | {{:tools:woodshop:assembled_img_20210124_191109.jpg?400|}} | ||
Line 16: | Line 4: | ||
====== Blue Elephant CNC Sheet Router ELE1325ATC-R "Bumblebee" (working title) ====== | ====== Blue Elephant CNC Sheet Router ELE1325ATC-R "Bumblebee" (working title) ====== | ||
- | | Aliases | "PLACEHOLDER", "Woodshop CNC" | | + | | Aliases |"Woodshop CNC" | |
| Other References |<WRAP> | | Other References |<WRAP> | ||
Line 27: | Line 15: | ||
</WRAP>| | </WRAP>| | ||
- | | Josh / Eris | PLACEHOLDER Please provide maintainer(s) name(s) | | + | | Maintainers | Ryan K, Josh H, Ale More | |
Line 33: | Line 21: | ||
- | PLACEHOLDER: Pick one of these three and delete this line. | ||
- | === Working === | ||
- | Machine is working as expected. | ||
<WRAP warning half round> | <WRAP warning half round> | ||
- | PLACEHOLDER Machine has some issue but is usable. please provide summary here | + | Machine is working. Please Contact Ryan Kirkpatrick or Ale More to use the machine. |
- | PLACEHOLDER NAME OF PERSON MARKING USABLE AND DATE | ||
- | <WRAP danger half round> | ||
- | === Out of Order === | ||
- | Machine is being commissioned. | ||
- | Eris Ryan tagged it out 24/01/2021 | ||
- | **This machine <wrap hi>requires induction</wrap> to use.** | + | **This machine requires supervision to use.** |
+ | Using the CNC requires a much higher level of knowledge than most tools. The basic process is as follows: | ||
- | PLACEHOLDER: Please make a simple diagram using [[draw.io|draw.io]] to show induction process. Delete this line. | + | - Start with a computer model of the part (CAD) |
- | + | - Create instructions (G-code) for the CNC controller (CAM) | |
- | {{:tools:woodshop:tablesaw-inductionflow.png?nolink|}} | + | - Cut out the part on the CNC |
- | INSERT LINK TO ONLINE COURSE HERE | + | |
- | Induction process is doing online video and quiz, then booking a time to do a practical exercise "making a speaker box". | + | If you don't have any familiarity with CNC work this video is a good place to start https://www.youtube.com/watch?v=YBGqknN3gGs. |
+ | If you're struggling with the process or would like some guidance please reach out on Discord. | ||
+ | ==== Specifications ==== | ||
- | ==== Guidelines ==== | + | ^ Item ^ Value ^ |
+ | | Post-processor | FANUC (Generic) | | ||
+ | | Spindle Max RPM | 18,000 | | ||
+ | | Spindle Taper | ISO 30 | | ||
+ | | Bed Size (mm) | X:1300 Y:2500 | | ||
+ | | 4th Axis Speed | 2000 deg/min | | ||
+ | | Automatic tool changer | Yes. Max 8 tools. | | ||
- | PLACEHOLDER: This is where you can document the usage practices for the machine generally. If this section gets very long, then it should be part of a canvas course for induction. Don't document maintenance procedures here, please do that below in the maintenance section. Delete this line. | ||
Line 101: | Line 83: | ||
<WRAP round download half left> | <WRAP round download half left> | ||
Line 118: | Line 97: | ||
- | <WRAP center round download half left > | + | <WRAP round download half left > |
==== Software ==== | ==== Software ==== | ||
Line 129: | Line 108: | ||
https://drive.google.com/drive/folders/1gGaesrOJUUI9Nfo9VuVv5VRvlFOpksIS?usp=sharing | https://drive.google.com/drive/folders/1gGaesrOJUUI9Nfo9VuVv5VRvlFOpksIS?usp=sharing | ||
+ | <WRAP clear></WRAP> | ||
- | <WRAP center round download half right> | + | <WRAP round download half right> |
==== Vacuum Pump Manual ==== | ==== Vacuum Pump Manual ==== | ||
Line 193: | Line 173: | ||
- | ===== RACI ===== | ||
- | PLACEHOLDER A RACI is an important documentation process to let people know what ACTIONS can happen, and who needs to be Responsible, Accountable, Consulted and Informed for each ACTION. Delete this line. | ||
- | <WRAP column third> | ||
- | | Modification and Repairs | - | AC | C | I | I | I | R | | ||
- | <WRAP clear></WRAP> | ||
- | PLACEHOLDER: Risk assessment is important to ensure we are making tools available to members in a responsible fashion. Please make every effort to do a reasonable risk assessment. If there is a safety incident with the tool, please redo a risk assessment and add it to the table. | ||
- | | 0001 | DEATH | Intolerable | Probable | 11 | PLACEHOLDER Induction to train users in correct usage | Low | Improbable | 1 | | ||
- | | 0002 | Crushing Injury | Intolerable | Possible | 11 | Induction to train users. Warning signage. Tripwire boundary. Emergency Stop buttons | | | | | ||
- | | 0003 | Cuts | Undesirable | Possible | 8 | Induction to train users. Tool access by change receptacles only. | | | | ||
- | | 0004 | Damage to Machine Bed or holding equipment | Undesirable | Possible | 8 | Induction to train users. (more...) | | | | ||
- | | 0005 | work piece ejected from machine | Undesirable | Possible | 8 | Induction. Sufficient holding equipment. (safety curtains?) | | | | ||
===== Decision Register ===== | ===== Decision Register ===== |
- tools/woodshop/cnc_sheet_router
