tools:woodshop:dustextraction [2020/08/02 17:05] ale |
tools:woodshop:dustextraction [2020/11/22 21:20] (current) devians |
- | ====== Introduction ====== | ||
- | {{ :causes:woodshop-room.jpg?400&nolink}} | + | ====== Centralised Dust Extraction ====== |
+ | ===== Introduction ===== | ||
+ | {{:tools:woodshop:woodman-de25sec-dust-extractor-2.jpg?400&nolink|}} | ||
Dust extraction is a work-in-progress. At the moment we have a portable unit and the main dust collection system. | Dust extraction is a work-in-progress. At the moment we have a portable unit and the main dust collection system. | ||
The main dust collector comprises a fixed 150mm ducting around the shop, different set of blast gates and an Arduino controlled dust collector. The main controller for the system can be found in the middle of the shop. | The main dust collector comprises a fixed 150mm ducting around the shop, different set of blast gates and an Arduino controlled dust collector. The main controller for the system can be found in the middle of the shop. | ||
- | ====== Status of the project ====== | ||
- | ===== what we have done ===== | ||
- | ==== 2/08/2020: ==== | + | Further reading: http://billpentz.com/woodworking/cyclone/index.php#index.php |
+ | ===== Status of the project ===== | ||
+ | ==== what we have done ==== | ||
+ | {{ :tools:woodshop:plumbedbeltdiscsander.jpg?200|The Belt/disc Sander fully plumbed to the system}} | ||
+ | === 2/08/2020: === | ||
* The main 150mm ducting is done | * The main 150mm ducting is done | ||
* Most of the blast gates have been assembled and glued (first stage). | * Most of the blast gates have been assembled and glued (first stage). | ||
Line 13: | Line 22: | ||
* The CAT cabling is all done. | * The CAT cabling is all done. | ||
* The Belt/disc sander has been properly plumbed and connected to the dust collection system. | * The Belt/disc sander has been properly plumbed and connected to the dust collection system. | ||
- | ===== What we need to do ===== | + | ==== What we need to do ==== |
- | ==== 02/08/2020 ==== | + | === 02/08/2020 === |
* build last-miles and connect the machines to the system. | * build last-miles and connect the machines to the system. | ||
Line 20: | Line 29: | ||
* Move forward with the development of the blast gates. | * Move forward with the development of the blast gates. | ||
- | ====== Last-mile====== | + | ===== Last-mile ===== |
Last-mile is the last bit of plumbing that's needed to connect a machine to the main system. Commonly you will have a blast-gate that will reduce the 150mm pipe to a 120/100/60(mm) pipe. From there you will have to go creative mode-on to figure out how to connect the machine. | Last-mile is the last bit of plumbing that's needed to connect a machine to the main system. Commonly you will have a blast-gate that will reduce the 150mm pipe to a 120/100/60(mm) pipe. From there you will have to go creative mode-on to figure out how to connect the machine. | ||
- | ===== Guidelines ===== | + | ==== Guidelines ==== |
Here's a couple of guidelines on how to do this properly: | Here's a couple of guidelines on how to do this properly: | ||
- Try to use rigid pipe in order to improve airflow | - Try to use rigid pipe in order to improve airflow | ||
- Don't modify the machine on a destructive way (eg. make holes on the machine, remove/cut parts of the machine, etc). If you feel that there's no other way "because life", you can always bring the subject to discord or wednesday's woodshop meetings. You will see that two brains think better that one, and you might find out that there's a better, more efficient way to do so. | - Don't modify the machine on a destructive way (eg. make holes on the machine, remove/cut parts of the machine, etc). If you feel that there's no other way "because life", you can always bring the subject to discord or wednesday's woodshop meetings. You will see that two brains think better that one, and you might find out that there's a better, more efficient way to do so. | ||
- In order to not modify machinery, you can always use different methods to hold stuff, like using VHB TAPE (Very High Bond double side tape) and zip ties. | - In order to not modify machinery, you can always use different methods to hold stuff, like using VHB TAPE (Very High Bond double side tape) and zip ties. | ||
- | ===== Tips and tricks ===== | + | ==== Tips and tricks ==== |
In general terms, the piping on a central dust collection system will be made up of a main duct (bigger diameter, I our case is 150mm) and then you will have drops for the machines that are going to be smaller in diameter. | In general terms, the piping on a central dust collection system will be made up of a main duct (bigger diameter, I our case is 150mm) and then you will have drops for the machines that are going to be smaller in diameter. | ||
Line 34: | Line 43: | ||
- | ====== Blast gates ====== | + | ===== Blast gates ===== |
The blast gates are a project in itself. At this stage they are being installed to be used manually, and in the future they will be automatically controlled. | The blast gates are a project in itself. At this stage they are being installed to be used manually, and in the future they will be automatically controlled. | ||
- | ====== Known Problems ====== | + | ===== Known Problems ===== |
- | * 02/08/2020 The system could turn unresponsive after it has been idle for a certain time. Momentarily solution: Turn it off and on again using the switch beside the plug. Permanent solution: fix the Arduino code. | + | |
+ | ^ Date ^ Description ^ Workaround ^ Proposed Remediation ^ | ||
+ | | 02/08/2020 | The system could turn unresponsive after it has been idle for a certain time. | Turn it off and on again using the switch beside the plug. | Fix the Arduino code. | | ||
- tools/woodshop/dustextraction.1596351923
