tools:woodshop:lathe_-_vicmarc_vl200 [2020/10/07 15:29] antifoo |
tools:woodshop:lathe_-_vicmarc_vl200 [2021/01/08 12:04] antifoo [Modifications / Repair History] |
Line 3: | Line 3: | ||
- | ====== PLACEHOLDER BRAND MODELNUMBER MACHINENAME ====== | + | ====== Vicmark Lathe VL200 ====== |
| Aliases | Vicmark VL200 | | | Aliases | Vicmark VL200 | | ||
| The Better Lathe |<WRAP> | | The Better Lathe |<WRAP> | ||
Line 13: | Line 13: | ||
[[https://forum.hsbne.org/search?q=table%20saw|Forum Posts]] | [[https://forum.hsbne.org/search?q=table%20saw|Forum Posts]] | ||
+ | [[https://trello.com/c/pIHzU3OF|Trello Card]] | ||
</WRAP>| | </WRAP>| | ||
Line 28: | Line 30: | ||
Ale, Josh and Murray are currently working on this. | Ale, Josh and Murray are currently working on this. | ||
+ | See [[https://trello.com/c/pIHzU3OF|Trello Card]] | ||
Line 38: | Line 42: | ||
- | PLACEHOLDER: Please make a simple diagram using [[draw.io|draw.io]] to show induction process. Delete this line. | ||
- | {{:tools:woodshop:tablesaw-inductionflow.png?nolink|}} | ||
- | PLACEHOLDER: Please document the steps required to go through induction. A summary paragraph and then an ordered list. Delete this line. | ||
- | Induction process is doing this and that and then doing something or other. | ||
- | - Watch induction video | ||
- | - Demonstrate you can operate the lathe safely | ||
- | - Make something nice for the assessor | ||
Line 68: | Line 61: | ||
- | PLACEHOLDER: Please fill out this table with all relevant machine specifications. The manufacturers website usually gives a good list. Delete this line. | + | {{:tools:woodshop:vl200_parts.png|}} |
+ | | 1 | Outboard Spindle / Handwheel | | ||
+ | | 2 | Headstock Spindle | | ||
+ | | 3 | Toolrest | | ||
+ | | 4 | Camlock / Banjo | | ||
+ | | 5 | Quill | | ||
+ | | 6 | Tailstock | | ||
+ | | 7 | Tailstock handwheel | | ||
+ | | 8 | Tailstock locking lever | | ||
+ | | 9 | Speed Controller / Inverter | | ||
+ | | 10 | Motor | | ||
+ | | 11 | Toolrest locking lever | | ||
+ | | 12 | Camlock / Banjo Locking lever | | ||
Line 108: | Line 117: | ||
{{ :tools:woodshop:woodshop-lathe-s1100v_user_manual.pdf | Speed Controller Manual}} | {{ :tools:woodshop:woodshop-lathe-s1100v_user_manual.pdf | Speed Controller Manual}} | ||
+ | {{ :tools:woodshop:vicmarc-lathe-owners-manual-2016.pdf | Vicmarc Lathe Manual (All Models)}} | ||
+ | {{ :tools:woodshop:4-jaw-chuck-manual-aug-10.pdf | Vicmarc 4-Jaw Chuck Manual }} | ||
Line 116: | Line 129: | ||
- | (TBA) | + | Vicmarc |
- | * E sales@example.com | + | * [[https://vicmarc.com/]] |
- | * P 00 0000 0000 | + | |
Line 141: | Line 152: | ||
| --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | | --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of accessory | **PLACEHOLDER Accessory Name** \\ PLACEHOLDER Description and usage notes for accessory | PLACEHOLDER Describe location of accessory | PLACEHOLDER Link to where it was bought from | | + | | {{:tools:woodshop:4_jaw_chuck.jpeg?100}} | Workpiece Holding | **4 Jaw Self-Centring Chuck** \\ VM120 V00285-1 For general work holding. \\ {{ :tools:woodshop:4-jaw-chuck-manual-aug-10.pdf | Vicmarc 4-Jaw Chuck Manual }} | TBA | TBA | |
+ | | {{:tools:woodshop:drive_dog.jpeg?100}} | Workpiece Holding | **Drive Dog** \\ 25mm Heavy Duty V00341 MT2 drive dog for inserting in the headstock spindle. | TBA | TBA | | ||
+ | | {{:tools:woodshop:live_centre.jpeg?100}} | Workpiece Holding | **Live Centre** \\ MT2 Cone Heavy Duty V00269 live centre for inserting in the tailstock. | TBA | TBA | | ||
+ | | {{:tools:woodshop:face_plate.jpeg?100}} | Workpiece Holding | **Face Plate** \\ 125mm faceplate V00412-1; For holding large pieces for roughing | TBA | TBA | | ||
+ | | {{:tools:woodshop:wood_screw.jpeg?100}} | Workpiece Holding | **Screw Point** \\ For mounting small cross grain pieces | TBA | TBA | | ||
+ | | {{:tools:woodshop:chuck_tools.jpeg?100}} | Accessory Tooling | **Chuck Tools** 10mm and 4mm T-Handled Allen Key Wrenches | TBA | TBA | | ||
===== Consumables & Running Costs ===== | ===== Consumables & Running Costs ===== |
- tools/woodshop/lathe_-_vicmarc_vl200
duncang
