tools:woodshop:lathe_-_vicmarc_vl200 [2020/11/22 19:51] duncang [Table] |
tools:woodshop:lathe_-_vicmarc_vl200 [2021/01/10 20:16] (current) duncang [Manufacturer] |
Line 125: | Line 125: | ||
Line 134: | Line 132: | ||
- | * Mr. Re seller | + | * Details TBA |
- | === Known Identical Models === | + | |
- | * Links to other machines that are a rebrand or similar | ||
Line 152: | Line 144: | ||
| --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | | --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | ||
- | | {{:tools:woodshop:4_jaw_chuck.jpeg?100|}} | Workpiece Holding | **4 Jaw Self-Centring Chuck** \\ For general work holding. \\ {{ :tools:woodshop:4-jaw-chuck-manual-aug-10.pdf | Vicmarc 4-Jaw Chuck Manual }} | TBA | TBA | | + | | {{:tools:woodshop:4_jaw_chuck.jpeg?100}} | Workpiece Holding | **4 Jaw Self-Centring Chuck** \\ VM120 V00285-1 For general work holding. \\ {{ :tools:woodshop:4-jaw-chuck-manual-aug-10.pdf | Vicmarc 4-Jaw Chuck Manual }} | TBA | TBA | |
- | | {{:tools:woodshop:drive_dog.jpeg?100|}} | Workpiece Holding | **Drive Dog** \\ MT2 drive dog for inserting in the headstock spindle. | TBA | TBA | | + | | {{:tools:woodshop:drive_dog.jpeg?100}} | Workpiece Holding | **Drive Dog** \\ 25mm Heavy Duty V00341 MT2 drive dog for inserting in the headstock spindle. | TBA | TBA | |
- | | {{:tools:woodshop:live_centre.jpeg?100|}} | Workpiece Holding | **Live Centre** \\ MT2 live centre for inserting in the tailstock. | TBA | TBA | | + | | {{:tools:woodshop:live_centre.jpeg?100}} | Workpiece Holding | **Live Centre** \\ MT2 Cone Heavy Duty V00269 live centre for inserting in the tailstock. | TBA | TBA | |
- | | {{:tools:woodshop:face_plate.jpeg?100|}} | Workpiece Holding | **Face Plate** \\ For holding large pieces for roughing | TBA | TBA | | + | | {{:tools:woodshop:face_plate.jpeg?100}} | Workpiece Holding | **Face Plate** \\ 125mm faceplate V00412-1; For holding large pieces for roughing | TBA | TBA | |
- | | {{:tools:woodshop:wood_screw.jpeg?100|}} | Workpiece Holding | **Screw Point** \\ For mounting small cross grain pieces | TBA | TBA | | + | | {{:tools:woodshop:wood_screw.jpeg?100}} | Workpiece Holding | **Screw Point** \\ For mounting small cross grain pieces | TBA | TBA | |
- | | {{:tools:woodshop:chuck_tools.jpeg?100|}} | Accessory Tooling | **Chuck Tools** 10mm and 4mm T-Handled Allen Key Wrenches | TBA | TBA | | + | | {{:tools:woodshop:chuck_tools.jpeg?100}} | Accessory Tooling | **Chuck Tools** 10mm and 4mm T-Handled Allen Key Wrenches | TBA | TBA | |
- tools/woodshop/lathe_-_vicmarc_vl200.1606038694
duncang
