tools:woodshop:lathe_-_vicmarc_vl200 [2020/11/22 20:02] duncang [Table] |
tools:woodshop:lathe_-_vicmarc_vl200 [2021/01/10 20:16] (current) duncang [Manufacturer] |
Line 125: | Line 125: | ||
Line 134: | Line 132: | ||
- | * Mr. Re seller | + | * Details TBA |
- | === Known Identical Models === | + | |
- | * Links to other machines that are a rebrand or similar | ||
Line 152: | Line 144: | ||
| --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | | --/10/2020 | External Speed Controller | Start/Stop & speed control dial added | Start/Stop button and a speed control dial wired to controller. Controller registers adjusted to use terminal inputs | <~$50 | | ||
- tools/woodshop/lathe_-_vicmarc_vl200.1606039342
- by duncang
