tools:woodshop:tablesaws [2021/02/14 00:56] ale [Modifications / Repair History] |
tools:woodshop:tablesaws [2021/09/19 12:58] ale [Table] |
+ | ~~TOC 1-4~~ | ||
Line 4: | Line 5: | ||
Line 22: | Line 14: | ||
Line 31: | Line 23: | ||
+ | ====Induction=== | ||
<WRAP round info 50%> | <WRAP round info 50%> | ||
**This machine <wrap hi>requires induction</wrap>.** | **This machine <wrap hi>requires induction</wrap>.** | ||
Line 46: | Line 39: | ||
* Joshua Hogendorn | * Joshua Hogendorn | ||
* Ale More | * Ale More | ||
+ | ====Guidelines==== | ||
+ | === How to use the microadjustment === | ||
+ | **Note:** To have a better understanding of this technique, you might want to check [[tools:woodshop:tablesaws#crosscut_fence_stops1|the modifications that we made to the endstops]]. | ||
+ | - With the swivel hard against the stop, set the stop to a dimension that's smaller than the nominal dimension by an amount that you think is suitable (E.g. how much macro-adjustment you need). | ||
+ | - Back the swivel paying attention to the gauge on the micro-adjustment knob and go pass the nominal dimension. | ||
+ | - Take a cut, measure using the method of your preference and adjust accordingly. | ||
Line 85: | Line 88: | ||
Line 91: | Line 94: | ||
Line 98: | Line 101: | ||
Line 131: | Line 134: | ||
| - | Joshua H & Ian Redmond | Rise and fall gear/worm totally worn and failed. | Replacement parts ordered but incorrect due to machine revision. Fix found by rotating gear 180º to unworn section | ~$150 | | | - | Joshua H & Ian Redmond | Rise and fall gear/worm totally worn and failed. | Replacement parts ordered but incorrect due to machine revision. Fix found by rotating gear 180º to unworn section | ~$150 | | ||
| - | Ryan Marple & Ale Moré | Rise and fall gear/worm totally worn and failed. | Parts were milled, specifically, holes were slotted to allow the installation of a different size worm wheel. | -| | | - | Ryan Marple & Ale Moré | Rise and fall gear/worm totally worn and failed. | Parts were milled, specifically, holes were slotted to allow the installation of a different size worm wheel. | -| | ||
+ | | 14/02/2021 | Ryan Marple & Ale Moré | The stops couldn't be calibrated with ease | Crosscut endstops were modified with and adjustable bullseye | -| | ||
Line 137: | Line 141: | ||
{{:tools:woodshop:table_saw_stop_1.jpg?400|}} {{:tools:woodshop:table_saw_stop_2.jpg?400|}} | {{:tools:woodshop:table_saw_stop_1.jpg?400|}} {{:tools:woodshop:table_saw_stop_2.jpg?400|}} | ||
- | === How to use the microadjustment === | ||
- | - With the swivel hard against the stop, set the stop to a dimension that's smaller than the nominal dimension by an amount that you think is suitable (E.g. how much macro-adjustment you need). | ||
- | - Back the swivel paying attention to the gauge on the micro-adjustment knob and go pass the nominal dimension. | ||
- | - Take a cut, measure using the method you preferred and adjust accordingly. | ||
Line 176: | Line 173: | ||
- tools/woodshop/tablesaws
