tools:woodshop:tablesaws [2021/02/15 14:04] ale [Modifications / Repair History] |
tools:woodshop:tablesaws [2021/09/19 12:56] ale |
+ | ~~TOC 1-4~~ | ||
Line 4: | Line 5: | ||
Line 22: | Line 14: | ||
Line 50: | Line 42: | ||
====Guidelines==== | ====Guidelines==== | ||
- | === Crosscut Fence Stops === | + | === How to use the microadjustment === |
- | The crosscut fence stops have been modified to be more accurate and easily corrected if needed. By design, the modification doesn't take into account any adjustments you make using the micro-adjustment. In other words, the bullseye is 100% accurate only when the swivel arm is hard against the fixed part of the stop. Having said that, it doesn't mean that you can't use the micro-adjustment, you just need to plan ahead (which is commonly the case with micro-adjustments). | + | |
- | {{:tools:woodshop:table_saw_stop_1.jpg?400|}} {{:tools:woodshop:table_saw_stop_2.jpg?400|}} | + | |
- | == How to use the microadjustment == | + | |
+ | **Note:** To have a better understanding of this technique, you might want to check [[tools:woodshop:tablesaws#crosscut_fence_stops1|the modifications that we made to the endstops]]. | ||
- With the swivel hard against the stop, set the stop to a dimension that's smaller than the nominal dimension by an amount that you think is suitable (E.g. how much macro-adjustment you need). | - With the swivel hard against the stop, set the stop to a dimension that's smaller than the nominal dimension by an amount that you think is suitable (E.g. how much macro-adjustment you need). | ||
- Back the swivel paying attention to the gauge on the micro-adjustment knob and go pass the nominal dimension. | - Back the swivel paying attention to the gauge on the micro-adjustment knob and go pass the nominal dimension. | ||
Line 101: | Line 88: | ||
Line 107: | Line 94: | ||
Line 114: | Line 101: | ||
Line 186: | Line 173: | ||
- tools/woodshop/tablesaws
