Next revision
tools:woodshop:tablesaws [2021/02/23 21:21]
ale
tools:woodshop:tablesaws [2022/02/26 15:42]
ale [Table]
Line 1: Line 1:
-~~NOTOC 2-3~~+~~TOC 1-4~~
 <WRAP column third> <WRAP column third>
 {{:​tools:​woodshop:​ps-12-sliding-table-panel-saw.jpg?​400&​nolink}} {{:​tools:​woodshop:​ps-12-sliding-table-panel-saw.jpg?​400&​nolink}}
Line 5: Line 5:
 <WRAP column twothirds>​ <WRAP column twothirds>​
 ====== Ledacraft PS-12 305mm Sliding Panel Table Saw ====== ====== Ledacraft PS-12 305mm Sliding Panel Table Saw ======
-| Aliases | "the table saw", "​PS12" ​ +| Aliases ​             | "the table saw", "​PS12" ​        ​
-| Other References |<​WRAP> ​ +| Other References ​    ​| <​WRAP> ​ //​[[https://​snipe.hsbne.org/​|Asset Register]]// ​   //​[[https://​xero.com/​|Xero Asset]]// ​   //​[[https://​portal.hsbne.org/​|Portal]]// ​   [[https://​forum.hsbne.org/​search?​q=table%20saw|Forum Posts]] ​ </​WRAP> ​
-//​[[https://​snipe.hsbne.org/​|Asset Register]]//​ +| Official Maintainer ​ Ale Moré        ​|
-//​[[https://​xero.com/​|Xero Asset]]// +
-//​[[https://​portal.hsbne.org/​|Portal]]//​ +
-[[https://​forum.hsbne.org/​search?​q=table%20saw|Forum Posts]] +
-</​WRAP>​| +
-| Official Maintainer | Joshua Hogendorn ​|+
 </​WRAP>​ </​WRAP>​
 <WRAP clear></​WRAP>​ <WRAP clear></​WRAP>​
Line 23: Line 14:
 <WRAP warning 50% round> <WRAP warning 50% round>
-=== Usable ===+==== Usable ​====
 The scribing blade mechanism has been removed for servicing. The scribing blade mechanism has been removed for servicing.
Line 97: Line 88:
 ===== Manufacturer ===== ===== Manufacturer =====
-=== Ledacraft ===+==== Ledacraft ​====
   * E sales@ledamachinery.com.au   * E sales@ledamachinery.com.au
Line 103: Line 94:
   * [[https://​www.ledamachinery.com.au/​leda_product/​ps-12-1600mm-sliding-table-panel-saw/​]]   * [[https://​www.ledamachinery.com.au/​leda_product/​ps-12-1600mm-sliding-table-panel-saw/​]]
-=== Reseller ===+==== Reseller ​====
   * Lance Dargusch ​   * Lance Dargusch ​
Line 110: Line 101:
   * M 0408 765 922   * M 0408 765 922
-=== Known Identical Models ===+==== Known Identical Models ​====
   * [[https://​www.carbatec.com.au/​machinery-and-accessories/​tablesaws-and-accessories/​tablesaws/​ts-p1600p]] ​   * [[https://​www.carbatec.com.au/​machinery-and-accessories/​tablesaws-and-accessories/​tablesaws/​ts-p1600p]] ​
Line 131: Line 122:
 ===== Modifications / Repair History ===== ===== Modifications / Repair History =====
-^ Date ^ Modified By ^ Description ^ Remediation ^ Cost ^ +^ Date        ^ Modified By             ​^ Description ​        ^ Remediation ​        ​^ Cost   ​
-| - | Joshua H | Rise/fall and angle handles fell apart | machined some adapters and used a surpus handle from the A331 | <$5 | +| -           ​| Joshua H                | Rise/fall and angle handles fell apart        ​| machined some adapters and used a surpus handle from the A331                                                       ​| <​$5 ​
-| - | Joshua H | Ratcheting handles that secure the sliding table extension broke | replaced by better ones from ebay | ~$40 | +| -           ​| Joshua H                | Ratcheting handles that secure the sliding table extension broke        ​| replaced by better ones from ebay        ​| ~$40   ​
-| - | Joshua H | Angle indication on front inaccurate | shimmed with washers to be accurate | - | +| -           ​| Joshua H                | Angle indication on front inaccurate ​        ​| shimmed with washers to be accurate ​        ​| -
-| - | Joshua H | Screw for changing scribing blade height was inappropriate and crashing with table surface, and wearing due to flathead design. | Replaced with appropriate grub screw | <$5 | +| -           ​| Joshua H                | Screw for changing scribing blade height was inappropriate and crashing with table surface, and wearing due to flathead design. ​ | Replaced with appropriate grub screw        | <​$5 ​
-| - | Joshua H | 90º fence stop for sliding table fence deemed unusable | replacement mechanism designed in CAD, machined by members and installed. | - | +| -           ​| Joshua H                | 90º fence stop for sliding table fence deemed unusable ​        ​| replacement mechanism designed in CAD, machined by members and installed. ​                                          ​| -
-| - | Craig Hudson | Riving knife always higher than blade, stopping joinery cuts. | Riving knife modified to allow for correct height for joinery | - | +| -           ​| Craig Hudson ​           | Riving knife always higher than blade, stopping joinery cuts.        | Riving knife modified to allow for correct height for joinery ​                                                      ​| -
-| - | Joshua H | Sliding table fence scale hard to make accurate | Stop at end of sliding table fence replaced with wooden block tuned to make the scale on fence accurate | - | +| -           ​| Joshua H                | Sliding table fence scale hard to make accurate ​        | Stop at end of sliding table fence replaced with wooden block tuned to make the scale on fence accurate ​            ​| -
-| - | Joshua H | Sliding table fence angle lock bolt stretched and worn by overtightening | replaced by parts from jig kit | - | +| -           ​| Joshua H                | Sliding table fence angle lock bolt stretched and worn by overtightening ​                                                        ​| replaced by parts from jig kit        | -
-| - | Joshua H | Sliding table clamp post unhardened and raising burrs | part hardened by forge cause | - | +| -           ​| Joshua H                | Sliding table clamp post unhardened and raising burrs        | part hardened by forge cause        | -
-| - | Joshua H & Ian Redmond | Rise and fall gear/worm totally worn and failed. | Replacement parts ordered but incorrect due to machine revision. Fix found by rotating gear 180º to unworn section | ~$150  | +| -           ​| Joshua H & Ian Redmond ​ | Rise and fall gear/worm totally worn and failed. ​        ​| Replacement parts ordered but incorrect due to machine revision. Fix found by rotating gear 180º to unworn section ​ | ~$150  |
-| - | Ryan Marple & Ale Moré | Rise and fall gear/worm totally worn and failed. | Parts were milled, specifically,​ holes were slotted to allow the installation of a different size worm wheel. | -| +| -           ​| Ryan Marple & Ale Moré  | Rise and fall gear/worm totally worn and failed. ​        ​| Parts were milled, specifically,​ holes were slotted to allow the installation of a different size worm wheel. ​      ​| -
-| 14/02/2021 | Ryan Marple & Ale Moré | The stops couldn'​t be calibrated with ease | Crosscut endstops were modified with and adjustable bullseye | -|+| 14/​02/​2021 ​ | Ryan Marple & Ale Moré  | The stops couldn'​t be calibrated with ease        ​| Crosscut endstops were modified with an adjustable bullseye ​                                                        ​| -      |
 +| 15/​01/​2022 ​ | Ale Moré                | Planned maintenance ​        | Change the arbour bearings ​        |        |
 ==== Crosscut Fence Stops ==== ==== Crosscut Fence Stops ====
Line 182: Line 175:
 | Quarterly | Assess and send blades for sharpening | | Quarterly | Assess and send blades for sharpening |
 | Monthly | Assess sliding table height and angle relative to main table and blade. Nominal 0.05-0.1mm proud of main table, parallel to blade. | | Monthly | Assess sliding table height and angle relative to main table and blade. Nominal 0.05-0.1mm proud of main table, parallel to blade. |
 +====Sharpening log====
 +^ Date        ^ Blade            ^ Notes                             ^
 +| 13/​09/​2021 ​ | TCG Acrylic ​     | Sharpen by Brisbane Saw Services ​ |
 +| 13/​09/​2021 ​ | TCG (Laminates) ​ | Sharpen by Brisbane Saw Services ​ |
 ===== RACI ===== ===== RACI =====
  • tools/woodshop/tablesaws
  • Last modified: 2 years ago
