tools:woodshop:thicknesserplaner [2021/02/13 18:28] ale [Induction] |
tools:woodshop:thicknesserplaner [2022/12/18 15:10] ale [16/04/2022] |
- | **PLACEHOLDER** | ||
Line 28: | Line 21: | ||
Line 43: | Line 36: | ||
- | In summary: | + | |
Line 92: | Line 69: | ||
Line 130: | Line 107: | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | + | | | General | Carbide inserts (13.8x13.8.x2.5 R150). | On the cutter head plastic box, inside the dewalt cart tool (pantorouter) | They can be bought for a cheaper price than felder in amazon. https://www.amazon.com.au/Hammer-Felder-Silent-Spiral-Cutter/dp/B06XKJP3PT | |
+ | ==== 28/03/2021 ==== | ||
+ | I've installed a new set of inserts on the cutter head. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More. | ||
+ | {{ :tools:woodshop:inset_changed_on_28.03.2021.jpg?direct&200 |}} | ||
+ | ==== 27/06/2021 ==== | ||
+ | ==== 16/04/2022 ==== | ||
- | ===== Maintenance ===== | + | {{ :tools:woodshop:img20220418105656.jpg?200 |}} |
- | ^ Interval ^ Task ^ | + | ==== 18/12/2022 ==== |
- | | PLACEHOLDER Pick one: Daily/Weekly/Monthly/Quarterly/Biannual/Annual | PLACEHOLDER Description of maintenance task and any relevant parameters | | + | I’ve replace the inserts with a whole new set. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More. |
