tools:woodshop:thicknesserplaner [2020/08/12 14:48] devians |
tools:woodshop:thicknesserplaner [2022/12/18 15:10] (current) ale [16/04/2022] |
+ | <WRAP column third> | ||
+ | {{:tools:woodshop:1948.png?nolink&400|}} | ||
+ | ====== Hammer A3-31 Planer/Thicknesser====== | ||
+ | | Aliases | Jointer/thickness planer, combination machine | | ||
+ | | Other References |<WRAP> | ||
+ | //[[https://snipe.hsbne.org/|Asset Register]]// | ||
+ | //[[https://xero.com/|Xero Asset]]// | ||
+ | //[[https://portal.hsbne.org/|Portal]]// | ||
+ | [[https://forum.hsbne.org/search?q=planer%20thicknesser%20jointer%20category%3A11|Forum Posts]] | ||
+ | </WRAP>| | ||
+ | | Official Maintainer | Ale Moré | | ||
+ | <WRAP clear></WRAP> | ||
+ | ===== Current Status ===== | ||
+ | <WRAP safety half round> | ||
+ | === Working === | ||
+ | Machine is working as expected. | ||
+ | ===== Usage ===== | ||
+ | <WRAP half round info > | ||
+ | **This machine <wrap hi>requires induction</wrap> to use.** | ||
+ | ==== Induction ==== | ||
+ | This machine's induction, as some others in the woodshop, is organized through a [[https://forum.hsbne.org/search?q=inductions%20between%20%23cause-effect%3Awoodworking%20order%3Alatest|forum post]]. In the following link, you will find more information about it. [[teams:woodworking:getting_around#what_machines_require_induction|Getting around - Inductions]] | ||
+ | ==== Guidelines ==== | ||
+ | PLACEHOLDER: This is where you can document the usage practices for the machine generally. If this section gets very long, then it should be part of a canvas course for induction. Don't document maintenance procedures here, please do that below in the maintenance section. Delete this line. | ||
+ | PLACEHOLDER: There is a large collection of PPE Icons in the "resources" folder. Please update these two columns with appropriate PPE recommendations. Columns of the tables are "Recommended/Required/Warning/Maintenance", PPE Icon and Description. Delete this line. | ||
+ | <WRAP column half> | ||
+ | | Recommended | {{:resources:ppe-wearearprotection.gif?nolink&100|}} | We recommend hearing protection. | | ||
+ | | Recommended | {{:resources:ppe-weargoggle.gif?nolink&100|}} | Please wear goggles or a face shield | | ||
+ | | Recommended | {{:resources:ppe-wearrespirator.gif?nolink&100|}} | We recommend the use of a respirator | | ||
+ | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&200|}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
+ | | Warning | {{:resources:ppe-wearhandprotection.gif?nolink&200|}} | Gloves are PPE against your material (splinters, resin etc) but are hazardous around the saw. Please carefully evaluate your use of gloves | | ||
+ | | Maintenance | {{:resources:ppe-disconnect.gif?nolink&200|}} | Disconnect power to the saw before performing maintenance, including blade changes | | ||
+ | PLACEHOLDER: Please fill out this table with all relevant machine specifications. The manufacturers website usually gives a good list. Delete this line. | ||
+ | ^ Name ^ Value ^ | ||
+ | | Attribute A | 305mm | | ||
+ | | Attribute B | 1600 mm x 270 mm | | ||
+ | | Attribute C | 3.0 hp | | ||
+ | PLACEHOLDER: Please copy the two WRAP blocks below for each file you upload relevant to this machine. This should be the manual at a minimum. Delete this line. | ||
+ | {{ :tools:woodshop:a331_manual.pdf | Manual }} | ||
+ | PLACEHOLDER: Document the manufacturer, things like contact person names, emails, phone numbers, product urls etc. Document the reseller we bought from, and any other sources for similar things. Delete this line. | ||
+ | === Manufacturer === | ||
+ | * E sales@example.com | ||
+ | * P 00 0000 0000 | ||
+ | * [[https://www.example.com/]] | ||
+ | === Reseller === | ||
+ | * Mr. Re seller | ||
+ | * Reseller Agencies | ||
+ | * E sales@reseller.com | ||
+ | * M 0000 000 000 | ||
+ | === Known Identical Models === | ||
+ | * Links to other machines that are a rebrand or similar | ||
+ | ^ Date ^ Description ^ Workaround ^ Proposed Remediation | | ||
+ | | 01/01/2020 | PLACEHOLDER Describe the problem | PLACEHOLDER Describe the workaround currently in place | Placeholder Describe a proposed fix or solution | | ||
+ | | 01/01/2020 | PLACEHOLDER NAME | PLACEHOLDER Describe what happened | PLACEHOLDER Describe how it was fixed or modified | PLACEHOLDER document the cost of the change | | ||
+ | | | PLACEHOLDER Category of accessory | **PLACEHOLDER Accessory Name** \\ PLACEHOLDER Description and usage notes for accessory | PLACEHOLDER Describe location of accessory | PLACEHOLDER Link to where it was bought from | | ||
+ | | | General | Carbide inserts (13.8x13.8.x2.5 R150). | On the cutter head plastic box, inside the dewalt cart tool (pantorouter) | They can be bought for a cheaper price than felder in amazon. https://www.amazon.com.au/Hammer-Felder-Silent-Spiral-Cutter/dp/B06XKJP3PT | | ||
+ | ==== 28/03/2021 ==== | ||
+ | I've installed a new set of inserts on the cutter head. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More. | ||
+ | {{ :tools:woodshop:inset_changed_on_28.03.2021.jpg?direct&200 |}} | ||
+ | ==== 27/06/2021 ==== | ||
+ | ==== 16/04/2022 ==== | ||
+ | ==== 18/12/2022 ==== | ||
+ | ===== RACI ===== | ||
+ | PLACEHOLDER A RACI is an important documentation process to let people know what ACTIONS can happen, and who needs to be Responsible, Accountable, Consulted and Informed for each ACTION. Delete this line. | ||
+ | | Modification and Repairs | - | AC | C | I | I | I | R | | ||
+ | PLACEHOLDER: Risk assessment is important to ensure we are making tools available to members in a responsible fashion. Please make every effort to do a reasonable risk assessment. If there is a safety incident with the tool, please redo a risk assessment and add it to the table. | ||
+ | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||^ | ||
+ | ^ ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | ||
+ | | 0001 | PLACEHOLDER DEATH | Intolerable | Probable | 11 | PLACEHOLDER Induction to train users in correct usage | Low | Improbable | 1 | | ||
+ | PLACEHOLDER: A decision register is for general documentation when some decision is made regarding the tool. To change its location, mode of operation, to buy an accessory, to replace something, to change how it operates etc. Delete this line. | ||
+ | | 0000 | Example decision | Provides an example | 08/08/20 | JH | Approved | JH | 08/08/20 | A line was put in the register | | ||
====== Thicknesser / Planer ====== | ====== Thicknesser / Planer ====== | ||
{{:tools:woodshop:1948.png?nolink&400|}} | {{:tools:woodshop:1948.png?nolink&400|}} |
- tools/woodshop/thicknesserplaner.1597207714
