causes:blacksmithing [2020/11/01 21:01] jabelone |
- | Leader: Alan Webb | + | {{ : causes:forge.jpeg?direct&400|The forge area}} |
- | ---- | + | <WRAP> |
- | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the art of blacksmithing, metal forging and sand casting. | + | |**Location** | The Forge is in the Hardstand, immediately to your right after the first container. | |
+ | |**Cause Leader** | To be updated | | ||
+ | |**Objective** | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/blacksmithing|Forum Category]] \\ [[https://discord.gg/mfURB4|Discord Chat]] \\ [[https://trello.com/invite/b/tTIJx7YS/c528d5acd464469b4903db1a5881b4d3/forge|Trello Task Tracking]] | | ||
- | To maintain a clean, safe and organised smithy, there will be some small tasks that members will have to complete: | + | </WRAP> |
- | After each use, the user much: | ||
- | - Ensure that all tools are put away in their designated areas after use. | + | ===== Cause Area Expectations ===== |
+ | ===== Member Owned Equipment on Loan ===== | ||
+ | ===== Ongoing Budgets ===== | ||
- | Monthly takes: | + | |
+ | - stocktake of fuel | ||
+ | - stocktake of tools | ||
- causes/blacksmithing
zacmarcus
