causes:blacksmithing [2019/09/04 21:15] |
causes:blacksmithing [2020/11/01 21:07] jabelone [Blacksmithing and Casting Cause] |
- | Cause Leader: Alan Webb | + | <panel> |
- | ---- | + | {{ : causes:forge.jpeg?direct&400|The forge area}} |
+ | |**Location** | The Forge is in the Hardstand, immediately to your right after the first container. | | ||
+ | |**Cause Leader** | Alex (@wixted) | | ||
+ | |**Objective** | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/blacksmithing|Forum Category]] \\ [[https://discord.gg/XpMznccTEt|Discord Chat]] \\ [[https://trello.com/invite/b/tTIJx7YS/c528d5acd464469b4903db1a5881b4d3/forge|Trello Task Tracking]] | | ||
+ | </panel> | ||
- | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | + | ===== Cause Area Expectations ===== |
+ | ===== Member Owned Equipment on Loan ===== | ||
+ | ===== Ongoing Budgets ===== | ||
When finished using the cause area, members must: | When finished using the cause area, members must: | ||
- causes/blacksmithing
