causes:blacksmithing [2020/04/12 17:08] nogthree |
- | Leader: Alan Webb | + | <panel> |
- | ---- | + | **Location:** The Forge is in the Hardstand, immediately to your right after the first container..\\ |
+ | **Cause Leader:** \\ | ||
+ | </panel> | ||
- | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the art of blacksmithing, metal forging and sand casting. | + | ===== Cause Owned Equipment ===== |
- | To maintain a clean, safe and organised smithy, there will be some small tasks that members will have to complete: | + | ===== Member Owned Equipment on Loan ===== |
- | After each use, the user much: | ||
- | - Ensure that all tools are put away in their designated areas after use. | + | ===== Ongoing Budgets ===== |
- | Monthly takes: | + | |
+ | - stocktake of fuel | ||
+ | - stocktake of tools | ||
- causes/blacksmithing
