Next revision | Previous revision Next revision Both sides next revision | ||
causes:craftpunk [2020/04/11 12:01] 127.0.0.1 external edit |
causes:craftpunk [2020/12/05 20:03] lonepiper_paula |
- | {{ :causes:placeholder.png |}} | + | ====== Craftpunk Cause ====== |
- | ====== Craftpunk ====== | + | {{ :causes:craftpunk.jpg?direct&600}} |
- | **Location:** The Craft Punk room is the room on the right at the end of the Green Room.\\ | + | |**Location** | The Craftpunk room is the room on the right at the end of the Green Room.| |
+ | |**Cause Leader** | Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, LonePiper and Pommygirl) \\ A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]]| | ||
- | **Cause Leader:** Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, Lonepiper and Pommygirl) \\ | + | </WRAP> |
- | A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]] | + | |
- | + | ===== Cause Area Expectations ===== | |
- | **Objective:** Craft Punk is a Cause dedicated to the more artistic pursuits of HSBNE members. Craft Punk specialises in cosplay, sewing, moulding and casting, painting, models, pottery and kiln firing, screen printing, sculpture, etc. We want to make crafting fun and accessible for HSBNE members and the greater community.\\ | + | |
- | **Current goals:** | + | |
- | * Restructure room to be more usable | + | |
- | * Run classes | + | |
- | **Members:** See [[https://portal.hsbne.org/group/list/|Craftpunk members]]\\ | + | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-craftpunk\\ | + | |
- | **Operating Policy:** [[https://wiki.hsbne.org/causes/craftpunk/operatingpolicy|Policy]] | + | |
- | ===== Cause Area Expectations (Copied from Cause Policy) ===== | + | |
Line 34: | Line 27: | ||
Line 39: | Line 37: | ||
+ | | Metex Tumblex-Gleam | {{ :causes:craftpunk:msds:tumblex_gleam_msds_34-651-000.pdf |MSDS}} | ??? |??? | | ||
+ | | Borax 10 Mol | {{ :causes:craftpunk:msds:boraxg_msds.pdf |MSDS}} | ??? | ??? | | ||
+ | | Sodium Bi-Sulphate - Jewellery Pickle | {{ :causes:craftpunk:msds:sodium_bisulphate_msds_sbs-sds-english-can.pdf |MSDS}} | ??? | ??? | | ||
Line 45: | Line 62: | ||
Line 54: | Line 70: | ||
- causes/craftpunk
