causes:craftpunk [2020/04/12 17:09] nogthree |
causes:craftpunk [2020/10/20 19:21] lonepiper_paula |
- | {{ :causes:placeholder.png |}} | + | ====== Craftpunk Cause ====== |
- | ====== Craftpunk ====== | + | {{ :causes:craftpunk.jpg?nolink |}} |
**Location:** The Craft Punk room is the room on the right at the end of the Green Room.\\ | **Location:** The Craft Punk room is the room on the right at the end of the Green Room.\\ | ||
- | **Cause Leader:** Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, Lonepiper and Pommygirl) \\ | + | **Cause Leader:** Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, LonePiper and Pommygirl) \\ |
A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]] | A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]] | ||
Line 12: | Line 12: | ||
**Current goals:** | **Current goals:** | ||
* Restructure room to be more usable | * Restructure room to be more usable | ||
- | * Run classes | ||
**Members:** See [[https://portal.hsbne.org/group/list/|Craftpunk members]]\\ | **Members:** See [[https://portal.hsbne.org/group/list/|Craftpunk members]]\\ | ||
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-craftpunk\\ | + | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] Look for #cause-craftpunk \\ [[https://trello.com/invite/b/J7b0EuZv/69f27f078a75d3b7f9dee423f1f09cf2/craftpunk-wad|Trello Task Tracking]] | |
- | + | **Operating Policy:** [[causes:craftpunk:operatingpolicy|Policy]] | |
- | **Operating Policy:** [[https://wiki.hsbne.org/causes/craftpunk/operatingpolicy|Policy]] | + | |
</panel> | </panel> | ||
- | ===== Cause Area Expectations (Copied from Cause Policy) ===== | + | |
Line 34: | Line 33: | ||
===== Craftpunk Tools ===== | ===== Craftpunk Tools ===== | ||
Line 45: | Line 62: | ||
Line 54: | Line 70: | ||
- causes/craftpunk
