causes:craftpunk [2020/10/20 19:18] lonepiper_paula |
- | {{ :causes:placeholder.png |}} | + | ====== Craftpunk Cause ====== |
- | ====== Craftpunk ====== | + | {{ :causes:craftpunk.jpg?nolink |}} |
**Location:** The Craft Punk room is the room on the right at the end of the Green Room.\\ | **Location:** The Craft Punk room is the room on the right at the end of the Green Room.\\ | ||
Line 12: | Line 12: | ||
**Current goals:** | **Current goals:** | ||
* Restructure room to be more usable | * Restructure room to be more usable | ||
- | * Run classes | ||
**Members:** See [[https://portal.hsbne.org/group/list/|Craftpunk members]]\\ | **Members:** See [[https://portal.hsbne.org/group/list/|Craftpunk members]]\\ | ||
Line 18: | Line 17: | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-craftpunk\\ | **Communications:** [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-craftpunk\\ | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/craft-punk|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://trello.com/invite/b/J7b0EuZv/69f27f078a75d3b7f9dee423f1f09cf2/craftpunk-wad|Trello Task Tracking]] | | ||
**Operating Policy:** [[causes:craftpunk:operatingpolicy|Policy]] | **Operating Policy:** [[causes:craftpunk:operatingpolicy|Policy]] | ||
</panel> | </panel> | ||
Line 34: | Line 35: | ||
===== Craftpunk Tools ===== | ===== Craftpunk Tools ===== | ||
Line 45: | Line 64: | ||
Line 54: | Line 72: | ||
- causes/craftpunk
