causes:craftpunk [2020/10/20 19:47] lonepiper_paula |
- | {{ :causes:placeholder.png |}} | + | {{ :causes:craftpunk.jpg? }} |
- | <panel> | + | <WRAP> |
- | **Cause Leader:** Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, Lonepiper and Pommygirl) \\ | + | |**Location** | The Craft Punk room is the room on the right at the end of the Green Room.| |
+ | |**Objective** | Craft Punk is a Cause dedicated to the more artistic pursuits of HSBNE members. Craft Punk specialises in cosplay, sewing, moulding and casting, painting, models, pottery and kiln firing, screen printing, sculpture, etc. We want to make crafting fun and accessible for HSBNE members and the greater community.\\| | ||
+ | |**Current Goals** | Restructure room to be more usable | | ||
- | **Current goals:** | ||
- | * Run classes | ||
- | </panel> | ||
Line 34: | Line 27: | ||
===== Craftpunk Tools ===== | ===== Craftpunk Tools ===== | ||
Line 45: | Line 56: | ||
Line 54: | Line 64: | ||
- causes/craftpunk
