causes:craftpunk [2020/10/11 16:00] lonepiper_paula Made a space for consumables/MSDS info |
causes:craftpunk [2020/12/08 19:13] lonepiper_paula |
- | <panel> | + | <WRAP> |
- | **Current goals:** | ||
- | </panel> | ||
Line 44: | Line 38: | ||
===== Craftpunk Consumables/MSDS ===== | ===== Craftpunk Consumables/MSDS ===== | ||
- | Craftpunk keeps a supply of a number of consumables relates to the tools in Craftpunk and some other useful things. If you appreciated having these consumables available please drop some money in the Craftpunk donation tin so that we can replenish them. Some things have a listed value, some don't. | + | Craftpunk keeps a supply of a number of consumables related to the tools in Craftpunk, and some other useful things. If you appreciated having these consumables available please drop some money in the Craftpunk donation tin when you use them, so that we can replenish them. Some things have a listed value, some don't. |
+ | | Airbrush Paint | {{ :causes:craftpunk:msds:creative_pl_airbrush_colour_msds.pdf |MSDS}}| Art Suppliers | User Selected Donation | | ||
- | == Adhesives == | ||
- | PVA Glue {{ :causes:craftpunk:msds:pva-craft-glue.pdf |MSDS}} | ||
===== Events and Classes ===== | ===== Events and Classes ===== |
- causes/craftpunk
