causes:craftpunk [2020/10/11 17:25] lonepiper_paula |
causes:craftpunk [2020/12/05 20:03] lonepiper_paula |
- | <panel> | + | <WRAP> |
- | **Current goals:** | ||
- | </panel> | ||
Line 46: | Line 40: | ||
Craftpunk keeps a supply of a number of consumables related to the tools in Craftpunk, and some other useful things. If you appreciated having these consumables available please drop some money in the Craftpunk donation tin when you use them, so that we can replenish them. Some things have a listed value, some don't. | Craftpunk keeps a supply of a number of consumables related to the tools in Craftpunk, and some other useful things. If you appreciated having these consumables available please drop some money in the Craftpunk donation tin when you use them, so that we can replenish them. Some things have a listed value, some don't. | ||
- | === Adhesives === | ||
- | PVA Glue - {{ :causes:craftpunk:msds:pva-craft-glue.pdf |MSDS}} | ||
- | Tool Consumables | + | ^ Product ^ MSDS ^ Supplier ^ Cost | |
+ | | Metex Tumblex-Gleam | {{ :causes:craftpunk:msds:tumblex_gleam_msds_34-651-000.pdf |MSDS}} | ??? |??? | | ||
+ | | Borax 10 Mol | {{ :causes:craftpunk:msds:boraxg_msds.pdf |MSDS}} | ??? | ??? | | ||
+ | | Sodium Bi-Sulphate - Jewellery Pickle | {{ :causes:craftpunk:msds:sodium_bisulphate_msds_sbs-sds-english-can.pdf |MSDS}} | ??? | ??? | | ||
===== Events and Classes ===== | ===== Events and Classes ===== |
- causes/craftpunk
