causes:craftpunk [2020/10/11 18:00] lonepiper_paula |
causes:craftpunk [2020/12/08 19:19] lonepiper_paula |
- | <panel> | + | <WRAP> |
- | **Current goals:** | ||
- | </panel> | ||
Line 50: | Line 44: | ||
| PVA Glue| {{ :causes:craftpunk:msds:pva-craft-glue.pdf |MSDS}} | Most newsagents selling Monte Mart products |User Selected Donation | | | PVA Glue| {{ :causes:craftpunk:msds:pva-craft-glue.pdf |MSDS}} | Most newsagents selling Monte Mart products |User Selected Donation | | ||
| SupaGlue| {{ :causes:craftpunk:msds:sds_super_glue_1_en2.pdf |MSDS}} | Hardware Stores |User Selected Donation | | | SupaGlue| {{ :causes:craftpunk:msds:sds_super_glue_1_en2.pdf |MSDS}} | Hardware Stores |User Selected Donation | | ||
- | | Hot Glue Gun Glue Sticks | {{ :causes:craftpunk:msds:msds_-_hot_melt_glue_sticks_clear_bstgb0docs_72.pdf |MSDS}} | Hardware Stores |User Selected Donation | | + | | Hot Melt Glue Stick |{{ :causes:craftpunk:msds:msds_-_hot_melt_glue_sticks_clear_bstgb0docs_72.pdf |MSDS}} | Hardware Stores | $0.50 per stick | |
+ | | Sodium Bi-Sulfite - Jewellery Pickle | {{ :causes:craftpunk:msds:sodium_bisulphate_msds_sbs-sds-english-can.pdf |MSDS}} | [[https://www.jewellerssupplies.com.au/product/26106-pickle-compound-500g?categoryId=198|AJS]] , Coles or Woolworths| ??? | | ||
| British Paints Spray Paint| {{ :causes:craftpunk:msds:81b-line_british_paints_spray_easy_quick_drying_enamel-aus_sds.pdf |MSDS}} | Any Hardware |User Selected Donation | | | British Paints Spray Paint| {{ :causes:craftpunk:msds:81b-line_british_paints_spray_easy_quick_drying_enamel-aus_sds.pdf |MSDS}} | Any Hardware |User Selected Donation | | ||
+ | | Airbrush Paint | {{ :causes:craftpunk:msds:creative_pl_airbrush_colour_msds.pdf |MSDS}}| Art Suppliers | User Selected Donation | | ||
| Vacuum Pump Oil | {{ :tools:craftpunk:alcatel_300_oil_msds.pdf |MSDS}} | Unsure | User Selected Donation | | | Vacuum Pump Oil | {{ :tools:craftpunk:alcatel_300_oil_msds.pdf |MSDS}} | Unsure | User Selected Donation | | ||
- | + | ===Consumables without MSDS=== | |
- causes/craftpunk
