causes:craftpunk [2020/10/28 00:35] hsbnewiki Fixing image alignment. |
causes:craftpunk [2021/04/13 19:47] lonepiper_paula |
|**Location** | The Craftpunk room is the room on the right at the end of the Green Room.| | |**Location** | The Craftpunk room is the room on the right at the end of the Green Room.| | ||
|**Cause Leader** | Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, LonePiper and Pommygirl) \\ A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]]| | |**Cause Leader** | Craftpunk is using an anarchy-based model of self-governance, but notable Craftpunkians are Meka, Paula and Emily (They can be found on Discord as Boo, LonePiper and Pommygirl) \\ A clear explanation of this system can be found [[https://www.youtube.com/watch?v=FSbl16vTovU|here.]]| | ||
- | |**Objective** | Craftpunk is a Cause dedicated to the more artistic pursuits of HSBNE members. Craftpunk specialises in cosplay, sewing, moulding and casting, painting, models, pottery and kiln firing, screen printing, sculpture, etc. We want to make crafting fun and accessible for HSBNE members and the greater community.\\| | + | |**Objective** | Craftpunk aims to provide equipment, tools, workspace and a culture that enables members to work in a variety of crafting media.| |
|**Current Goals** | Restructure the room to be more usable. | | |**Current Goals** | Restructure the room to be more usable. | | ||
|**Members** | See [[https://portal.hsbne.org/group/list/|Craftpunk members]] | | |**Members** | See [[https://portal.hsbne.org/group/list/|Craftpunk members]] | | ||
Line 14: | Line 14: | ||
- | * Leave the area as clean or cleaner than you found it.\\ | + | * Only use tools you know how to use or have been inducted on.\\ |
- | * Please make sure to put money in the donation tin (see below) for consumables that you appreciated using so that we can replenish them.\\ | + | * Ask for help or guidance when you need it.\\ |
- | * Only use tools you know how to use or have been inducted on.\\ | + | * Leave the area as clean or cleaner than you found it.\\ |
- | * Ask for help or guidance when you need it.\\ | + | |
* Because art and creativity is subjective and personal, please do not provide unsolicited critique, suggestions or help with someone’s project. Instead, you may wish to offer your help, but allow the crafter to decline.\\ | * Because art and creativity is subjective and personal, please do not provide unsolicited critique, suggestions or help with someone’s project. Instead, you may wish to offer your help, but allow the crafter to decline.\\ | ||
Line 28: | Line 26: | ||
+ | * Please make sure to put money in the donation tin (see below) for consumables that you appreciated using so that we can replenish them.\\ | ||
{{:tools:craftpunk:img_20201011_124333.jpg?200|}} | {{:tools:craftpunk:img_20201011_124333.jpg?200|}} | ||
+ | ===== What is Craftpunk? ===== | ||
+ | Previously known as the "Createatorium", Meka started this cause around 2014 to expand on HSBNE's creative potential. | ||
+ | Craftpunk is a Cause dedicated to the more artistic pursuits of HSBNE members. Having its origins in Cosplay and Larping, crafts such as sewing, moulding and casting, jewellery, printing, painting, models, pottery and kiln firing, are to be found in Craftpunk. We want to make crafting fun and accessible for HSBNE members and the greater community. | ||
- | ===== Craftpunk Tools ===== | + | Our approach is to provide equipment, tools and a link to instruction, more so than providing materials and consumables. A limited supply of consumables are kept in Craftpunk, (see below). As a general rule, members supply the materials they are crafting with. |
- | <nspages tools:craftpunk -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | ===== Craftpunk Consumables/MSDS ===== | + | Craftpunk values creativity, cooperation and respectful behaviour towards others, the available equipment and the Space. |
- | Craftpunk keeps a supply of a number of consumables related to the tools in Craftpunk, and some other useful things. If you appreciated having these consumables available please drop some money in the Craftpunk donation tin when you use them, so that we can replenish them. Some things have a listed value, some don't. | + | |
- | ^ Product ^ MSDS ^ Supplier ^ Cost | | + | |
- | | PVA Glue| {{ :causes:craftpunk:msds:pva-craft-glue.pdf |MSDS}} | Most newsagents selling Monte Mart products |User Selected Donation | | + | |
- | | SupaGlue| {{ :causes:craftpunk:msds:sds_super_glue_1_en2.pdf |MSDS}} | Hardware Stores |User Selected Donation | | + | |
- | | Hot Glue Gun Glue Sticks | {{ :causes:craftpunk:msds:msds_-_hot_melt_glue_sticks_clear_bstgb0docs_72.pdf |MSDS}} | Hardware Stores |User Selected Donation | | + | |
- | | British Paints Spray Paint| {{ :causes:craftpunk:msds:81b-line_british_paints_spray_easy_quick_drying_enamel-aus_sds.pdf |MSDS}} | Any Hardware |User Selected Donation | | + | |
- | | Vacuum Pump Oil | {{ :tools:craftpunk:alcatel_300_oil_msds.pdf |MSDS}} | Unsure | User Selected Donation | | + | |
- | ===Consumables without MSDS=== | + | |
- | ^Product ^ Supplier ^ Cost | | + | |
- | |32mm Badge Blank |[[https://alond.com.au/32mm-badge-components-plastic-back-makes-100-badges-alond.html | Alond - 32mm plastic back badge kit.]]| $0.40 per blank set used.| | + | |
- | |58mm Badge Blank | [[https://alond.com.au/58mm-badge-components-plastic-back-makes-100-badges-alond.html | Alond - 58mm plastic back badge kit.]]| $0.50 per blank set used. | | + | |
+ | =====Monthly MeetUp===== | ||
+ | Craftpunk hosts a regular Monthly MeetUp on the first Saturday of each month from noon. It is open to all members of HSBNE and the general public. Come along and enjoy the company of fellow Hackers while you work on your current projects, or think about your future projects, or reminisce about the projects of the past. | ||
===== Events and Classes ===== | ===== Events and Classes ===== | ||
- | All of HSBNE's classes and events can be found [[https://www.eventbrite.com.au/o/hsbne-inc-4654630925|on Eventbrite]]. Craftpunk also runs regular events, such as Working Bees to improve our space, and Classes, so that members can learn a new skill in a relaxed, friendly environment.\\ | + | We have regular events such as Working Bees to improve our space, and Classes so that members and the public can learn a new skill in a relaxed, friendly environment.\\ |
+ | All of HSBNE's classes and events can be found [[https://www.eventbrite.com.au/o/hsbne-inc-4654630925|on Eventbrite]].\\ | ||
+ | * Monthly MeetUp - recurring on the first Monday of the month. 6.30pm. | ||
* No currently planned classes. | * No currently planned classes. | ||
=== Possible Future classes === | === Possible Future classes === | ||
- | * adapting a pattern | + | * Adapting a pattern |
- | * Screen printing multiple colours | + | |
- | * Screen printing monochrome- Photo-emulsion | ||
* Introduction to Sublimation Printing. | * Introduction to Sublimation Printing. | ||
===== Meetings ===== | ===== Meetings ===== | ||
Meetings are held to decide on cause goals and large (over $100) spending items.\\ | Meetings are held to decide on cause goals and large (over $100) spending items.\\ | ||
Meeting minutes can all be found here: [[meetings:causes:craftpunk:| Craftpunk minutes]]\\ | Meeting minutes can all be found here: [[meetings:causes:craftpunk:| Craftpunk minutes]]\\ | ||
- | Meeting minutes are kept on the Wiki, and cross-posted to the forums.\\ | + | Meeting minutes are kept on the Wiki and cross-posted to the forums.\\ |
Any member of Craftpunk can call a meeting.\\ | Any member of Craftpunk can call a meeting.\\ | ||
- | ===== History of Craftpunk ===== | ||
- | Previously known as the "Createatorium", Meka started this cause in _____ to expand on HSBNE's creative potential. | + | |
+ | ===== Inductions ===== | ||
+ | See the individual tool pages. | ||
+ | ===== Craftpunk Tools ===== | ||
+ | <nspages tools:craftpunk -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
+ | | Silver Solder | {{ :causes:msds_silver_solder_paste_420-850.pdf |MSDS}} | Australian Jewellery Suppliers | ??? | | ||
+ | | Airbrush Paint | {{ :causes:craftpunk:msds:creative_pl_airbrush_colour_msds.pdf |MSDS}}| Art Suppliers | User Selected Donation | | ||
+ | |Sewing Machine Oil | {{ :causes:craftpunk:msds:helmarmoil_sewing_machine_msds.pdf |MSDS}}| Craft Shops/Spotlight | $0.50 per sewing session | | ||
+ | |Acrylic Cement |{{ :causes:craftpunk:msds:acrylics_adhesive.pdf |MSDS}}|??? | ???| | ||
+ | |Protite Clear Casting & Embedding Resin |{{ :causes:craftpunk:msds:protite-clear-casting-embedding-resin.pdf |MSDS}} | ??? | ??? | | ||
+ | |Protite Resin Catalyst Hardener |{{ :causes:craftpunk:msds:protite-fibreglass-resin-catalyst-hardener-15ml.pdf |MSDS}} | ??? | ???| | ||
+ | |Sewing Machine - BLACK thread | [[https://www.spotlightstores.com/sewing-fabrics/haberdashery/sewing-threads/gutermann-polyester-thread-colours-0-99/80055391 | Gutterman Thread - from Spotlight or any good haberdashery.]] | $10 | | ||
+ | |Sewing Machine - WHITE Thread |[[https://www.spotlightstores.com/sewing-fabrics/haberdashery/sewing-threads/gutermann-polyester-thread-colours-0-99/BP80173074-1 |Gutterman Thread - from Spotlight or any good haberdashery. ]]| $10 | | ||
+ | | Overlocker - BLACK Thread |[[https://www.spotlightstores.com/sewing-fabrics/haberdashery/sewing-threads/birch-overlocking-thread-value-pack/BP80255428-black | Birch Overlocking Thread Value Pack - from Spotlight or any good haberdashery.]]| $20| | ||
+ | | Overlocker - WHITE Thread | [[https://www.spotlightstores.com/sewing-fabrics/haberdashery/sewing-threads/birch-overlocking-thread-value-pack/BP80255428-white |Birch Overlocking Thread Value Pack - from Spotlight or any good haberdashery. ]] | $20 | | ||
+ | | Embroidery - BLACK Thread | [[http://example.com|External Link]] | $?? | | ||
+ | | Embroidery - WHITE Thread | [[http://example.com|External Link]] | $?? | | ||
- causes/craftpunk
