causes:woodworking [2018/03/05 14:43] |
- | * All machinery requires induction. | + | * All machinery requires induction. |
- | * All machine or tool damage requires immediate reporting to contact@hsbne.org . | + | * All machine or tool damage requires immediate reporting to contact@hsbne.org . |
- | * Appropriate PPE usage is clearly signed and expected. | + | * Appropriate PPE usage is clearly signed and expected. |
- | * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. | + | * You are expected to clean up after you use the shop, do not leave projects on work surfaces, or dust/shavings/glue about the shop. |
- | * Return all tools to their home in the shop when done. | + | * Return all tools to their home in the shop when done. |
- | * Woodshop tools do not leave the woodshop. | + | * Woodshop tools do not leave the woodshop. |
- | * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. | + | * Use the marked sacrificial surfaces for most work, ie do not saw, hammer etc on the mitre station or machine surfaces. |
- | * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. | + | * Some tools have removable parts, when done with the tool all those parts should be reattached or placed back where you found them. |
- | * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. | + | * Machine maintenance is to be performed by named maintainers only, please do not attempt to modify any woodshop machines. |
- | ==== Shop Contents ==== | + | | Sandpaper | Roll 79mm @P240 | Drum Sander | - | 5m | 50m | |
+ | | Sandpaper | Roll 93mm @P120 | Hand and Powertool Sanding | - | 5m | 50m | | ||
+ | | Blades | Bandsaw 12mm 06TPI | N4400 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 25mm 04TPI | N4400 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 06mm 14TPI | BP-250 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 03mm 18TPI | BP-250 | 1 | 2 | 2 | | ||
+ | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | ||
- | * N4400 Bandsaw | ||
- | * H&F Mini Bandsaw | ||
- | * Radial Arm Saw | ||
- | * Disc Sander | ||
- | * Scrollsaw | ||
- | * Lathe | ||
- | === Power Tools === | ||
- | TBA | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
