infrastructure:services:memberportal [2019/08/16 11:18] |
infrastructure:services:memberportal [2020/04/11 12:01] 127.0.0.1 external edit |
- | ===== HSBNE Portal ===== | + | ===== HSBNE Portal (MemberMatters) ===== |
- | The HSBNE Portal is an open source, full featured membership portal. It is designed by and for HSBNE (Hackerspace Brisbane). It was created by Jaimyn in his spare time, with a little help from some HSBNE members. It can manage membership, access permissions, spacebucks, doors, interlocks and more! For more information please see the GitHub repo [[https://github.com/HSBNE/hsbneportal/|here]]. | + | The HSBNE Portal is open source software called MemberMatters and is a full featured membership portal. It is designed by and for HSBNE (Hackerspace Brisbane). It was created by [[https://github.com/jabelone/|Jaimyn]] in his spare time, with a little help from some HSBNE members. It can manage membership, access permissions, spacebucks, doors, interlocks and more! For more information please see the GitHub repo [[https://github.com/membermatters/MemberMatters|here]]. |
- | The HSBNE member portal runs inside a docker container on [[infrastructure:servers:porthack01|porthack01]]. It is primarily written in python and uses a locally stored sqlite database. There is an nginx reverse proxy on [[infrastructure:servers:porthack01|porthack01]] that manages SSL and proxies traffic from portal.hsbne.org to the right container. | + | The HSBNE member portal runs inside a docker container on [[infrastructure:servers:porthack01|porthack01]]. It is primarily written in python and JavaScript (Vue.js) and uses a locally stored sqlite database. There is an nginx reverse proxy on [[infrastructure:servers:porthack01|porthack01]] that manages SSL and proxies traffic from portal.hsbne.org to the right container. |
+ | The member portal also implements the [[https://spaceapi.io/|space API]], although it currently does not dynamically pull sensor information etc. | ||
===Useful Info=== | ===Useful Info=== | ||
Line 9: | Line 11: | ||
**Current Maintainer(s):** Jaimyn (@jabelone)\\ | **Current Maintainer(s):** Jaimyn (@jabelone)\\ | ||
**Running On:** [[infrastructure:servers:porthack01|Porthack01]]\\ | **Running On:** [[infrastructure:servers:porthack01|Porthack01]]\\ | ||
- | **GitHub:** [[https://github.com/HSBNE/hsbneportal|HSBNE Portal]] | + | **GitHub:** [[https://github.com/membermatters/MemberMatters|HSBNE Portal]] |
- infrastructure/services/memberportal
- by jabelone
