Both sides previous revision Previous revision | Next revision Both sides next revision | ||
tools:blacksmithing:gasbottlefurnace [2022/06/20 19:47] zacmarcus |
tools:blacksmithing:gasbottlefurnace [2022/06/20 19:49] zacmarcus |
Line 26: | Line 26: | ||
==== General ==== | ==== General ==== | ||
- | A cone (or mandrel) is for hammering barstock into perfect conical rings or scroll shapes. Has a hardy hole for tooling, such as a smaller cone for finer work. Has a tong slot so you can hold work without impacting the roundness. | + | Put material into forge to heat up. |
- | Made from Ductile Iron, weighs 173kg. | + | **Only put steel into the forge. No galvanised / zinc coated / stainless / copper / etc. If unsure, ask.** |
==== Potential improvements ==== | ==== Potential improvements ==== | ||
- | A wide, timber base that it is bolted to using a tapered, flat bar ring with tabs for bolts. Base should potentially include tubing for the forklift, or quick jack wheels. Priority - Low | + | A smaller, more efficient forge. |
==== Recommended PPE ==== | ==== Recommended PPE ==== |
- tools/blacksmithing/gasbottlefurnace
