tools:blacksmithing:gasbottlefurnace [2022/09/18 12:47] wixted [RACI] |
tools:blacksmithing:gasbottlefurnace [2023/03/09 19:10] zacmarcus [Gas Forge Standard Operating Procedure] |
Line 8: | Line 8: | ||
| Aliases | "the forge" | | | Aliases | "the forge" | | ||
| Official Maintainer | Alex Wixted | | | Official Maintainer | Alex Wixted | | ||
+ | | Owned by | [[teams:blacksmithing:Forge Team]] | | ||
+ | | Trainers | Alex / Jess | | ||
Line 29: | Line 31: | ||
- | - Read the "[[tools:blacksmithing:gasbottlefurnace#forge_area_induction|Forge Area Induction]]" below | + | - Read the "[[tools:blacksmithing:gasbottlefurnace#gas_forge_standard_operating_procedure|Gas Forge Standard Operating Procedure]]" below |
- Post in the Forge channel on [[https://chat.hsbne.org/forge|Discord]] to arrange for a time to be inducted | - Post in the Forge channel on [[https://chat.hsbne.org/forge|Discord]] to arrange for a time to be inducted | ||
Line 42: | Line 44: | ||
** Forge consumes $5 of LPG per hour while running. Please remember to donate to the forge. ** | ** Forge consumes $5 of LPG per hour while running. Please remember to donate to the forge. ** | ||
+ | ==== Addons ==== | ||
+ | | Adjustable roller for long material | | ||
==== Potential improvements ==== | ==== Potential improvements ==== | ||
Line 62: | Line 67: | ||
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc | | + | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc. Safety caps are recommended. | |
- | | | | | + | | Required | | Long pants required. | |
+ | | Required | | No Synthetic materials or clothing. | | ||
Line 74: | Line 80: | ||
- | ^ Task / Action ^ Executive ^ Cause Leader \\ Cause Team ^ Named Maintainer ^ Trainers ^ Cause ^ Membership ^ Implementer ^ | + | ^ Task / Action ^ Executive ^ Team Leader ^ Named Maintainer ^ Trainers ^ Team ^ Membership ^ Implementer ^ |
| Modification and Repairs | - | AC | C | I | I | I | R | | | Modification and Repairs | - | AC | C | I | I | I | R | | ||
| Induction changes | CI | CI | CI | ACI | I | I | R | | | Induction changes | CI | CI | CI | ACI | I | I | R | | ||
Line 90: | Line 96: | ||
^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||| | ||
| ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | | ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level | ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | ||
- | | 01 | Fire | Intolerable | Improbable | 10 | Induction to train users in correct usage, no flammables around forge | Low | Improbable | 1 | | | + | | 01 | Uncontained fire | Major | Likely | 16 - Extreme | Induction to train users in correct usage, no flammables around forge | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 02 | Silicosis | Intolerable | Improbable | 10 | Forge is regularly maintained | Low | Improbable | 1 | | | + | | 02 | Silicosis | Major | Possible | 12 - High | Forge is regularly maintained | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 03 | Fumes and vapours | Intolerable | Improbable | 10 | Induction to train users in correct usage | Low | Improbable | 1 | | | + | | 03 | Fumes and vapours | Severe | Possible | 15 - Extreme | Induction to train users in correct usage | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 04 | Flashbacks | Intolerable | Improbable | 10 | Induction to train users in correct usage | Low | Improbable | 1 | | | + | | 04 | Flashbacks | Moderate | Possible | 9 - High | Induction to train users in correct usage | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 05 | Explosion by gas leakage | Intolerable | Improbable | 10 | Induction to train users in correct usage | Low | Improbable | 1 | | | + | | 05 | Minor Explosion by improper lighting | Likely | Moderate | 12 - High | Induction to train users on how to light the forge | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 06 | Burn | Acceptable | Probable | 3 | Induction to train users in correct usage, wear PPE, water on hand, first aid kit | Low | Improbable | 1 | | | + | | 06 | Explosion from leakage from gas bottle | Severe | Unlikely | 10 - High | Induction to train users on how to detect and fix gas leak | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 07 | Flying sparks | Acceptable | Probable | 3 | Induction to train users in correct usage, wear PPE | Low | Improbable | 1 | | | + | | 07 | Minor Burn | Insignificant | Likely | 4 - Medium | Wear PPE, use appropriate tooling, water on hand, first aid kit | Unlikely | Insignificant | 2 - Low | Yes | |
- | | 08 | IR radiation burns to eyes and skin | Acceptable | Probable | 3 | Wear PPE | Low | Improbable | 1 | | | + | | 08 | Moderate Burn | Minor | Possible | 6 - Medium | Wear PPE, water on hand, use appropriate tooling, first aid kit | Unlikely | Insignificant | 2 - Low | Yes | |
+ | | 09 | Major Burn | Major | Unlikely | 8 - High | Wear PPE, use appropriate tooling, water on hand, first aid kit | Unlikely | Minor | 4 - Low | Yes | | ||
+ | | 10 | Flying Sparks | Insignificant | Likely | 4 - Medium | Wear PPE, water on hand, first aid kit | Unlikely | Insignificant | 2 - Low | Yes | | ||
+ | | 11 | Industrial Noise | Minor | Very Likely | High - 10 | Wear PPE | Unlikely | Insignificant | 2 - Low | Yes | | ||
+ | | 12 | IR radiation burns to eyes and skin | Minor | Likely | 10 | Wear PPE | Unlikely | Insignificant | 2 - Low | Yes | | ||
Line 103: | Line 113: | ||
- | ==== Forge Area Induction ==== | + | ==== Gas Forge Standard Operating Procedure ==== |
+ | **The Gas Forge induction must be completed in person prior to use. Post in the [[https://chat.hsbne.org/forge|Forge Discord]] channel to arrange a time.** | ||
**General PPE:** | **General PPE:** | ||
- | Required: | + | |
+ | Required PPE: | ||
- | * natural fibre clothing (Cotton, wool, hemp, denim, drill etc are all excellent choices.) | + | * Natural fibre clothing (Cotton, wool, hemp, denim, drill etc are all excellent choices.) |
- | Recommended: | + | Recommended PPE: |
- | * long sleeve shirt (natural fibre) | + | * Long sleeve shirt (natural fibre) |
- | * steel cap shoes | + | * Steel cap shoes |
- | * hat/cap (natural fibre) | + | * Hat/cap (natural fibre) |
* Apron | * Apron | ||
- | For use as necessary: | + | Use as necessary PPE: |
- | * #2- #3 shade brazing goggles | + | * Brazing goggles (shade #2 or #3) |
- | **How to light the gas forge:** | + | **SOP: Lighting the gas forge** |
* Ensure ball valve (yellow handle) is closed. | * Ensure ball valve (yellow handle) is closed. | ||
* Ensure air/venturi adjustment port is closed. | * Ensure air/venturi adjustment port is closed. | ||
* Connect gas bottle securely | * Connect gas bottle securely | ||
- | * Open gas bottle valve and check for leaks. If there’s leaks check and tighten connections. | + | * Open gas bottle valve and check for leaks by listening, smelling and using gas leak. If there are leaks check and tighten connections. |
* Adjust the gas flow valve to a medium flow. | * Adjust the gas flow valve to a medium flow. | ||
* Use some firelight or a long nose BBQ lighter to provide a pilot light in the forge. | * Use some firelight or a long nose BBQ lighter to provide a pilot light in the forge. | ||
Line 134: | Line 147: | ||
* Adjust gas flow valve and air/venturi port until desired burner strength is achieved. | * Adjust gas flow valve and air/venturi port until desired burner strength is achieved. | ||
- | **How to extinguish the gas forge:** | + | **SOP: Extinguishing the gas forge:** |
* If you are not finished forging for the day, you can use the ball valve for ease of use. Close the air/venturi port to prevent a heat chimney. While the forge is still red hot it will relight instantly. | * If you are not finished forging for the day, you can use the ball valve for ease of use. Close the air/venturi port to prevent a heat chimney. While the forge is still red hot it will relight instantly. | ||
- | * When you are finished forging for the day, close the valve on the gas bottle, and let the forge run until the line is clear of gas. Close the ball valve and air/venturi port, and disconnect the gas bottle. | + | * When you are finished forging for the day, close the valve on the gas bottle, and let the forge run until the line is clear of gas. Close the ball valve and air/venturi port, and disconnect the gas bottle. The yellow safety cap must be put back into the gas bottle and the gas bottle must go back into the gas storage cage even if the gas bottle is empty. |
- | **Do’s & don’ts of the gas forge:** | + | **Forge Best Practices:** |
* The gas forge is for steel only. No galvanised / zinc coated / stainless / copper / etc, If unsure, ask. Absolutely no hazardous materials such as lead should be placed into the forge – This will earn you an instant 3 month ban as we will need to replace the forge for safety. | * The gas forge is for steel only. No galvanised / zinc coated / stainless / copper / etc, If unsure, ask. Absolutely no hazardous materials such as lead should be placed into the forge – This will earn you an instant 3 month ban as we will need to replace the forge for safety. | ||
* Certain metals such as copper/brass/titanium may be used in the gas forge after a discussion around the required precautions. (eg: melted copper in the forge will permanently contaminate the forge and prevent all future forge welding from being successful. Precautions to avoid melting copper into the forge should be taken) | * Certain metals such as copper/brass/titanium may be used in the gas forge after a discussion around the required precautions. (eg: melted copper in the forge will permanently contaminate the forge and prevent all future forge welding from being successful. Precautions to avoid melting copper into the forge should be taken) |
- tools/blacksmithing/gasbottlefurnace
