tools:blacksmithing:gasbottlefurnace [2022/09/20 08:04] zacmarcus [Forge Area Induction] |
tools:blacksmithing:gasbottlefurnace [2023/03/09 19:12] (current) zacmarcus [Gas Forge Standard Operating Procedure] |
Line 8: | Line 8: | ||
| Aliases | "the forge" | | | Aliases | "the forge" | | ||
| Official Maintainer | Alex Wixted | | | Official Maintainer | Alex Wixted | | ||
- | | Owned by | Team Forge | | + | | Owned by | [[teams:blacksmithing:Forge Team]] | |
| Trainers | Alex / Jess | | | Trainers | Alex / Jess | | ||
Line 31: | Line 31: | ||
- | - Read the "[[tools:blacksmithing:gasbottlefurnace#forge_area_induction|Forge Area Induction]]" below | + | - Read the "[[tools:blacksmithing:gasbottlefurnace#gas_forge_standard_operating_procedure|Gas Forge Standard Operating Procedure]]" below |
- Post in the Forge channel on [[https://chat.hsbne.org/forge|Discord]] to arrange for a time to be inducted | - Post in the Forge channel on [[https://chat.hsbne.org/forge|Discord]] to arrange for a time to be inducted | ||
Line 44: | Line 44: | ||
** Forge consumes $5 of LPG per hour while running. Please remember to donate to the forge. ** | ** Forge consumes $5 of LPG per hour while running. Please remember to donate to the forge. ** | ||
+ | ==== Addons ==== | ||
+ | | Adjustable roller for long material | | ||
==== Potential improvements ==== | ==== Potential improvements ==== | ||
Line 110: | Line 113: | ||
- | ==== Forge Area Induction ==== | + | ==== Gas Forge Standard Operating Procedure ==== |
+ | **The Gas Forge induction must be completed in person prior to use. Post in the [[https://chat.hsbne.org/forge|Forge Discord]] channel to arrange a time.** | ||
- | **General PPE:** | + | **Required PPE:** |
- | Required: | + | |
- | * natural fibre clothing (Cotton, wool, hemp, denim, drill etc are all excellent choices.) | + | * Natural fibre clothing (Cotton, wool, hemp, denim, drill etc are all excellent choices.) |
- | Recommended: | + | **Recommended PPE:** |
- | * long sleeve shirt (natural fibre) | + | * Long sleeve shirt (natural fibre) |
- | * steel cap shoes | + | * Steel cap shoes |
- | * hat/cap (natural fibre) | + | * Hat/cap (natural fibre) |
* Apron | * Apron | ||
- | For use as necessary: | + | **Use as necessary PPE:** |
- | * #2- #3 shade brazing goggles | + | * Brazing goggles (shade #2 or #3) |
- | **How to light the gas forge:** | + | **SOP: Lighting the gas forge** |
* Ensure ball valve (yellow handle) is closed. | * Ensure ball valve (yellow handle) is closed. | ||
* Ensure air/venturi adjustment port is closed. | * Ensure air/venturi adjustment port is closed. | ||
Line 141: | Line 145: | ||
* Adjust gas flow valve and air/venturi port until desired burner strength is achieved. | * Adjust gas flow valve and air/venturi port until desired burner strength is achieved. | ||
- | **How to extinguish the gas forge:** | + | **SOP: Extinguishing the gas forge:** |
* If you are not finished forging for the day, you can use the ball valve for ease of use. Close the air/venturi port to prevent a heat chimney. While the forge is still red hot it will relight instantly. | * If you are not finished forging for the day, you can use the ball valve for ease of use. Close the air/venturi port to prevent a heat chimney. While the forge is still red hot it will relight instantly. | ||
- | * When you are finished forging for the day, close the valve on the gas bottle, and let the forge run until the line is clear of gas. Close the ball valve and air/venturi port, and disconnect the gas bottle. | + | * When you are finished forging for the day, close the valve on the gas bottle, and let the forge run until the line is clear of gas. Close the ball valve and air/venturi port, and disconnect the gas bottle. The yellow safety cap must be put back into the gas bottle and the gas bottle must go back into the gas storage cage even if the gas bottle is empty. |
- | **Do’s & don’ts of the gas forge:** | + | **Forge Best Practices:** |
* The gas forge is for steel only. No galvanised / zinc coated / stainless / copper / etc, If unsure, ask. Absolutely no hazardous materials such as lead should be placed into the forge – This will earn you an instant 3 month ban as we will need to replace the forge for safety. | * The gas forge is for steel only. No galvanised / zinc coated / stainless / copper / etc, If unsure, ask. Absolutely no hazardous materials such as lead should be placed into the forge – This will earn you an instant 3 month ban as we will need to replace the forge for safety. | ||
* Certain metals such as copper/brass/titanium may be used in the gas forge after a discussion around the required precautions. (eg: melted copper in the forge will permanently contaminate the forge and prevent all future forge welding from being successful. Precautions to avoid melting copper into the forge should be taken) | * Certain metals such as copper/brass/titanium may be used in the gas forge after a discussion around the required precautions. (eg: melted copper in the forge will permanently contaminate the forge and prevent all future forge welding from being successful. Precautions to avoid melting copper into the forge should be taken) | ||
Line 153: | Line 157: | ||
* Don't put hot tools back into the tool rack. Put them under the forge until they are cool to hold. | * Don't put hot tools back into the tool rack. Put them under the forge until they are cool to hold. | ||
- | General Forge Area Safety | + | **General Forge Area Safety** |
* Bring a water bottle – forging is hot work and you need to keep your hydration levels up. | * Bring a water bottle – forging is hot work and you need to keep your hydration levels up. | ||
* Always remove cut off hardy’s from the anvil hardy hole when not in use. | * Always remove cut off hardy’s from the anvil hardy hole when not in use. |
- tools/blacksmithing/gasbottlefurnace.1663625078
