tools:blacksmithing:gasbottlefurnace [2023/03/09 19:10] zacmarcus [Gas Forge Standard Operating Procedure] |
tools:blacksmithing:gasbottlefurnace [2023/03/09 19:12] (current) zacmarcus [Gas Forge Standard Operating Procedure] |
Line 117: | Line 117: | ||
**The Gas Forge induction must be completed in person prior to use. Post in the [[https://chat.hsbne.org/forge|Forge Discord]] channel to arrange a time.** | **The Gas Forge induction must be completed in person prior to use. Post in the [[https://chat.hsbne.org/forge|Forge Discord]] channel to arrange a time.** | ||
- | **General PPE:** | + | **Required PPE:** |
- | Required PPE: | + | |
Line 124: | Line 123: | ||
- | Recommended PPE: | + | **Recommended PPE:** |
* Long sleeve shirt (natural fibre) | * Long sleeve shirt (natural fibre) | ||
Line 131: | Line 130: | ||
* Apron | * Apron | ||
- | Use as necessary PPE: | + | **Use as necessary PPE:** |
* Brazing goggles (shade #2 or #3) | * Brazing goggles (shade #2 or #3) | ||
Line 158: | Line 157: | ||
* Don't put hot tools back into the tool rack. Put them under the forge until they are cool to hold. | * Don't put hot tools back into the tool rack. Put them under the forge until they are cool to hold. | ||
- | General Forge Area Safety | + | **General Forge Area Safety** |
* Bring a water bottle – forging is hot work and you need to keep your hydration levels up. | * Bring a water bottle – forging is hot work and you need to keep your hydration levels up. | ||
* Always remove cut off hardy’s from the anvil hardy hole when not in use. | * Always remove cut off hardy’s from the anvil hardy hole when not in use. |
- tools/blacksmithing/gasbottlefurnace.1678353004
