tools:digitalfabrication:3dprinters:leftcr10 [2020/08/26 18:47] jabelone Removed broken usb port warning |
tools:digitalfabrication:3dprinters:leftcr10 [2020/09/20 18:39] jabelone [Modifications / Repair History] |
Line 7: | Line 7: | ||
**Maintainers:** Drew Spriggs and Jaimyn Mayer | **Maintainers:** Drew Spriggs and Jaimyn Mayer | ||
- | **Maintenance:** | + | ===== Modifications / Repair History ===== |
- | **22/08/2020:** | + | |
- | Who: Jaimyn Mayer | + | |
- | Why: Needed to use 3D printer. | + | |
- | What: | + | |
- | * Changed filament over to PLA and flushed old filament out. | + | |
- | * Re-levelled bed while printing as it was not level. | + | |
+ | | xx/08/2020 | Scott and Jaimyn | Swapped the mainboards around on the printers to get them up and running again (mainly Scott). | 1hr of time | | ||
+ | | 22/08/2020 | Jaimyn | Bed was found to be not level and incorrect filament loaded. | Loaded new roll of PLA and flushed out hotend. Levelled bed by adjusting the screws on each corner. | 1hr of time | | ||
+ | | 17/09/2020 | Jaimyn | Bed was found to be not level and OctoPrint was offline. | Fixed OctoPrint by reseating all of the power/network cables and changing DNS over to new IP address. Added static IP. Levelled bed by adjusting the screws on each corner. | 2hrs of time | |
